NEED PICTURE OF 4AGE BLOCK..
Postby 1598cc » Fri Apr 22, 2005 1:09 pm
so im lucky i didnt blow the headgasket, instead a leak somehwere around the back of the block near where the alternator sits , started pissing out water so a hose came off or something.. ive heard there is a hose or something around the back, but ive never seen myself and there isnt much room to see, so need a picture of a engine with showing clearly the water line at back of block.
1598cc
Postby ee904age » Fri Apr 22, 2005 1:32 pm
What model 4AGE?
heres the back of a 16V.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby 1598cc » Fri Apr 22, 2005 1:36 pm
its actually a 4agze bigport but still same sorta shit i think.. alternators in back of engine .. alternator literally fell out 8O there was shit loads of steam coming from the right side of the block (in that picture) so just wondering where abouts it could have come from .
1598cc
Postby ee904age » Fri Apr 22, 2005 1:40 pm
My first guess is your water pump it F**ked.
90 SW20 N/A - Sold
ee904age
Postby 1598cc » Fri Apr 22, 2005 2:30 pm
was replaced not so long ago . mite have to take inlet manifold off and have a decent look as theres no way i can see it form above
1598cc
Postby pc » Fri Apr 22, 2005 2:39 pm
If you jack the car up and have a look from underneath you can see most of those pipes. If its not the water pump then maybe it is where the alternator mount thingie is on the water pipe on the top right hand side of the picture.
Maybe the mount has broken off, breaking the water pipe in the process.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby ee904age » Fri Apr 22, 2005 3:07 pm
Also, the top pipe in the pic is only sealed with an O ring where it goes into the housing, Ive had a few of them perish and leak
90 SW20 N/A - Sold
ee904age
Postby evil_si » Fri Apr 22, 2005 10:31 pm
the alternator tensioner is mounted to the cast pipe out let on the far right hand side of that picture,
there is a gasket behind that, and an oring seals the small pipe that comes out of it and runs across the back of the engine.
evil_si
Postby 1598cc » Sat Apr 23, 2005 3:21 pm
all good now . bolt came out of the bracket wher it holds the alternator and flange sorta thing for the radiator pipe..
1598cc
