toyota carbs
toyota carbs
Postby fuel » Sun Apr 24, 2005 8:04 pm
Ok
I've got a *cough* Mitsi.. it's an NZ-new model and has an Aisan twin barrell carby with vacuum operated secondarys. It's just a basic carb, doesn't have any electronics on it at all, apart from the fuel cut off solenoid.
Now, it's done monster milage, and hasn't been running very smooth for long. I had to rebuilt with new seals, accelerator pump, needle valve, gaskets. Had a good clean out too.
It didn't seem to make much of a difference, it still feels rough when accelerating, and uses even more fuel than ever before.
I'm beginning to think it's a very useless design of carby.
So.. I'm wondering if there were any 'good' Aisan carbs which were put on Toyota vehicles from the factory (either in NZ or in Japan).
I was thinking along the lines of a Corona or a Hiace or something with a 2.0L motor or bigger. I think my current carb has a 28mm primary and a 32mm secondary (or is it the other way around?).
Anyone have much experience with the Aisan carbys put on Toyotas? Need some ideas what vehicles to start searching for the carbs.
Cheers,
-Phil (annoyed mitsi owner).
LOUD NOISES!!!
fuel
Postby Ae92typeX » Sun Apr 24, 2005 10:34 pm
has the engine had any work done to it?, i mean with high mileage, how have you ascertained that the carby is at fault and not a combination of other worn out items?
Ae92typeX
Postby fuel » Mon Apr 25, 2005 12:05 am
Engine has done 393,000kms. Unsure if any previous owners have done any engine work on it.
When I got it about 70,000kms ago it used not much oil at all, possibly 500ml~1L between oil changes (10,000kms). In the last 20,000kms it's been alot worse. I replaced the headgasket and had the head refaced at 370,000kms, which bumped the compression from 185psi on all cylinders (hot) up to 205~225psi over the 4 cylinders again when hot. I haven't done a compression check within the last 12 months or so, so would be useful to know what it's at now.
Because of the head work, and no subsequent work to the bottom end, it's caused the rings to deteriate, and one of the big end bearings is a little rattly under load at 3000rpm. It doesn't really smoke until it's under heavy load and at high rpm - even then it's usually cloudy grey smoke like a diesel almost. I have yet to see it smoke blue smoke, but possibly because that's hard to detect.
I have serviced it often, oil changes every 10,000kms since owning it, and recently down to every 5,000kms now. Has a new air and fuel filter. Spark plugs are 8,000kms old and the electrodes are still nice and square. I plan on doing a rebuild before the 400,000kms mark or mid this year whichever suits. This will include but not limited to; new premium rings and a bore rehone, new bearings and crank if needed, all new seals and gaskets, new pistons if needed, new oil pump if needed, balance shaft removal and a new clutch. I just want to get the carby sorted before I do the motor.
Thing is, it will sometimes run nice and smooth when it wants to, but other times it will bog down, have hardly any torque around 2000~3000rpm and feels strained. Sometimes wont be smooth when accelerating either, seems notchy sometimes. You can feel on the pedal where the vacuum secondary opens.
I pretty much just want to ditch this carby altogether as it seems like junk . When I was at the carby rebuilders, he was dismantling a HiAce carby which happened to be an Aisan as well. Looked like a flash version of mine (ie bigger barrels, more advanced design). Just wondering if any of the Aisans fitted to the Toyotas were quite good, and if anyone could recommend a certain one.
LOUD NOISES!!!
fuel
Postby fuel » Tue Apr 26, 2005 9:57 pm
Anyone?
LOUD NOISES!!!
fuel
Postby rwd_mayhem » Thu Apr 28, 2005 1:12 am
there r no good toyota carbs, go to philspeed.co.nz, get an adapter plate and a weber, off ya go no problems.
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
