AE82 Diagnosis Codes :S
Postby XS1V » Tue Apr 26, 2005 3:46 pm
I had an engine light flash up a while ago so did a diagnosis check and got nine flashes. Went and looked in the haynes workshop book at the codes and it says nine flashes - not used so i rechecked to make sure i had counted rite and got nine again. Anyone had this happen??
XS1V
Postby Spannergal » Tue Apr 26, 2005 4:14 pm
was there a break between flashs eg instead of flash pause flash to nine times, it could have been flash pause flash long pause and flash pause seven times, which would be a code for 27. should be a distinct enough break to be able to tell. hope that helps.
just a random number pulled out of my head
Spannergal
Postby ChaosAD » Tue Apr 26, 2005 9:24 pm
Thats haynes manuals for ya.
I had a code 9 and code 11.
one was the speed sensor the other was something to do with the fact that I have removed the air/con.
Cant remember which was which though.
Look up the code 11
ChaosAD
Postby ee904age » Tue Apr 26, 2005 9:28 pm
My list has code 11 as:
ECU (+B) - Momentary interuption in power supply to ECU.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby ee904age » Tue Apr 26, 2005 9:32 pm
Oh, and I dont know if its relevant, but Ive seen a list with code 72 (which could be your 9 flashes) as:
72:
AIR CONDITIONER COMPRESSOR RELAY/RELAY SIGNAL
--A/C COMPRESSOR RELAY/CIRCUIT
--ECU
90 SW20 N/A - Sold
ee904age
Postby matt dunn » Tue Apr 26, 2005 10:45 pm
ee904age wrote:Oh, and I dont know if its relevant, but Ive seen a list with code 72 (which could be your 9 flashes) as:
72:
--ECU
Codes 1 to 11 are for cars with map sensors.
codes 11 to 100 are for cars with airflow meters.
I have both sets but only the AFM codes with me.
11 - MAIN ECM POWER
12 - REV SIGNAL (ENGINE)
13 - NO REV SIGNAL TO ECU
14 - CONNECTION BETWEEN EIM AND ECU
15 - CONNECTION BETWEEN EIM AND ECU
16 - ECM CPU
17 - RIGHT HAND SIDE CAM SENSOR
18 - LEFT HAND SIDE CAM SENSOR
21 - O2 SENSOR
22 - COOLANT TEMP SENSOR
24 - IAT SENSOR
25 - AIR FUEL MIXTURE
26 - AIR FUEL MIXTURE
27 - SECONDARY O2 SENSOR
28 - O2 SENSOR
29 - SECONDARY O2 SENSOR
31 - AFM (or MAP)
32 - AFM
34 - TURBO CHARGE BOOST SENSOR SIGNAL
35 - TURBO CHARGE BOOST SENSOR SIGNAL
41 - TPS SIGNAL
42 - VSS SIGNAL
43 - STARTER SIGNAL
51 - A/C SWITCH SIGNAL
52 - LEFT SIDE KNOCK SENSOR
53 - KNOCK SENSOR CONTROL UNIT
54 - TURBO CHARGE CONDENSER CONTROL UNIT SIGNAL
55 - RIGHT SIDE KNOCK SENSOR SIGNAL
I will get the others and post them back as these will be the wrong codes for you.
Matt
Postby ee904age » Tue Apr 26, 2005 11:12 pm
90 SW20 N/A - Sold
ee904age
Postby XS1V » Wed Apr 27, 2005 8:09 am
Yeah it was definatly nine short flashes aye, i have a map sensored car so :S i havent had the light again, it was just after having the engine out, maybe a loose plug (i checked them and repushed plugs to make sure they were in)ust curious as to what it was
XS1V
Users browsing this forum: Bing [Bot] and 24 guests
