2fas4u wrote: which is easier to hook up the sensor wire too, the neg of igntion coil or the pin out on the ecu?
excellent! now which colour wire behind the instrument cluster do i hook up to on the existing rev meter?matt dunn wrote:2fas4u wrote: which is easier to hook up the sensor wire too, the neg of igntion coil or the pin out on the ecu?
Neither.
On a SW20 that already has a tacho it is easier to pull out the instrument cluster and hook into the existing tacho feed.
Matt
wat do these letters short for? i spose p=pulse, n=negative?aesc wrote:If your going off the back of the dash cluster then it wont be a wire, but there are heaps of screws back there going into the back of the cluster itself. On mine I hooked onto the screw 'P' but it could be something different on an mr2, like N-
Users browsing this forum: Bing [Bot] and 20 guests
