can't find neg terminal of ignition coil
Postby 2fas4u » Sat Apr 30, 2005 6:12 pm
hi could someone pleeeeeeeeeeeeeeeeeeeeease show me a pic of what the factory ignition coil looks like on a 1990 MR2 with a 3SGE engine. i searched and searched but no much luck and one diagram was so poorly drawn i couldn't make anything of it. where precisely is it? i spent the whole day looking in the engine bay trying the follow the leads off the distributor minus the ignition coil to no avail :cry: :cry: :cry:
2fas4u
Postby suberimakuri » Sat Apr 30, 2005 6:43 pm
neg of tacho is the smaller of the two wires that plug into the tacho.
you'll also find it going to the diagnostic box in the engine bay.
suberimakuri
Postby 2fas4u » Sat Apr 30, 2005 7:03 pm
Karl_Skewes wrote:neg of tacho is the smaller of the two wires that plug into the tacho.
thanks but which hole do i poke it into in the diagnostic box?
2fas4u
Postby suberimakuri » Sat Apr 30, 2005 7:16 pm
have a look under the cap, it'll say what's on what... tacho i think.
suberimakuri
Postby 2fas4u » Sat Apr 30, 2005 9:57 pm
nothing on my diagnostic box say about ignition.
2fas4u
Postby 2fas4u » Sat Apr 30, 2005 11:07 pm
included is a pic of wat my engine bay looks like, which lead from the distributer do i follow to get to the ignition coil?
2fas4u
Re: can't find neg terminal of ignition coil
Postby matt dunn » Sun May 01, 2005 9:57 pm
2fas4u wrote: i spent the whole day looking in the engine bay trying the follow the leads off the distributor to the ignition coil
The wires from the dist do not go to the coil, that is why.
The wires from the dist go to the ecu. Then different wires go to the igniter, and a third lot of wires go from the igniter to the coil.
So you will never find a wire from the dist to the coil except the HT lead.
Looking for a tacho feed? Try the EXT wire on the igniter. You may have to take it off and turn it over to read the labels. they are on the black plastic plug part.
Matt
Postby 2fas4u » Sun May 01, 2005 11:22 pm
aren't those two statements contradicting, cos the top one you are saying that there are no coils going from distributor to coil, but the high tension coil. but then in the second you are saying the only coil going from distributor to the ignitin coil is the high tension coil. :?
2fas4u
Postby 2fas4u » Sun May 01, 2005 11:45 pm
according to this diagram:
the only cable going to the distributor is from ignition coil, but looking in the engine bay, there are two going to two different places.
and in this one:
Image wat is that cylinder directly below the radiator cap cos one of the cables from the distributor goes to that cylinder and another cable from the distributor goes to another cylindrical similar looking thing further down under the air filter box.[/img]
2fas4u
Postby suberimakuri » Mon May 02, 2005 12:36 am
said before, the smaller of the two wires on the coil willl give you high tacho feed as you ask for.
It just also goes to the diagnostic box, which will require less soldering.
suberimakuri
Postby Adydas » Mon May 02, 2005 12:41 am
you said you have a 3sge
but that diagram mite not help seems it says 3sgte and 3sfe ( im sure its the same but im sure you see what im getting at )
Adydas
Postby suberimakuri » Mon May 02, 2005 12:49 am
the tacho wire is normally black with red dots too.....
but you'd do better checking the integral connector diagram on www.motec.com.au
suberimakuri
Postby 2fas4u » Mon May 02, 2005 12:55 am
Karl_Skewes wrote:said before, the smaller of the two wires on the coil willl give you high tacho feed as you ask for.
that the box with the white writing on top by the bottom left corner? cheers, will look out for black wire with red dots :D cheers. 8)
2fas4u
Postby matt dunn » Mon May 02, 2005 1:31 am
2fas4u wrote:according to this diagram:
If you read and understand the diagram, the wire shown from the dist to coil IS the HT lead as it goes to the centre of the rotor.
If you understand how the system works you will also know that the two magnetic pickups that are shown are actually inside the dist although they are not shown like that in the diagram.
And as to my two quotes contradicting each other,
I was presuming that you were not dumb enough to think that you can hook a monster tacho into the HT lead,
but it seems that you maybe you are.
You have been given numerous ways and locations of hooking it up by lots of different people on here all of which will work.
Matt
Postby suberimakuri » Mon May 02, 2005 9:26 am
no. wrong box.
and wtf do you want a monster tacho for anyways?
suberimakuri
