thanks but which hole do i poke it into in the diagnostic box?Karl_Skewes wrote:neg of tacho is the smaller of the two wires that plug into the tacho.
you'll also find it going to the diagnostic box in the engine bay.
2fas4u wrote: i spent the whole day looking in the engine bay trying the follow the leads off the distributor to the ignition coil
The wires from the dist do not go to the coil, that is why.
So you will never find a wire from the dist to the coil except the HT lead.
that the box with the white writing on top by the bottom left corner? cheers, will look out for black wire with red dotsKarl_Skewes wrote:said before, the smaller of the two wires on the coil willl give you high tacho feed as you ask for.
It just also goes to the diagnostic box, which will require less soldering.
2fas4u wrote:according to this diagram:
the only cable going to the distributor is from ignition coil, but looking in the engine bay, there are two going to two different places.
