TPS Slop
TPS Slop
Postby dotdog » Thu May 05, 2005 1:23 pm
Hey all, My car has become real jurky going on and coming off throttle, so ive adjusted my tps which has fixed it sorta,
but when i was adjusting it i noticed about 2mm slop between when the trottle starts moving and the contacts start moving,
Is this normal, or is the 300000 odd kms that the motor has done starting to show up?
Michael
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
dotdog
Postby ee904age » Thu May 05, 2005 6:50 pm
Just put a 4E in there and be done with it :wink:
Have you got a spare to test it with? Have you got the TPS specs? It *should* be moving directly with the throttle,
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby dotdog » Thu May 05, 2005 7:41 pm
Na man, 4e's are for nana's 12 valves are where the real power is at, ive got another one to check agaist, but that has done 270000kms as well
dotdog
