NO Electrics unless above 3000rpm.?
Postby 1598cc » Thu May 05, 2005 6:18 pm
Levin started playing up ; the rev counter, dashlights, windows, starter motor etc wont go BUT if i turn the key to on, roll start the car, itll fire up and drive with no electrics then if i drive above sorta 3000rpm then everything will work . kinda weird.
ive check the fuses on the batteryand the ALT one has blown out but i know why thats happend ; so i connected it back up rugged to see if it fixs it but no joy..
any other places to look
1598cc
Postby ee904age » Thu May 05, 2005 6:36 pm
Alternator brushes bung? Check the alternator output with a multimeter and that should give your answer.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Re: NO Electrics unless above 3000rpm.?
Postby matt dunn » Thu May 05, 2005 9:12 pm
1598cc wrote:roll start the car, itll fire up and drive with no electrics then if i drive above sorta 3000rpm then everything will work . kinda weird.
So the car wont start under it's own battery power?
Buggered if I know why people try and solve electrical problems in a car with a battery that is obviously no good.
If that battery wont start the car, get it tested or buy a new one.
And a 20 min spin round the block will not charge up a really flat battery.
The reason everything will go above 3000rpm is cause the alt will kick in and power everything up.
Matt
Postby 1598cc » Thu May 05, 2005 9:26 pm
nah it was doing this even before the battery went flat. its just i havnt driven it for a week and its flat as. ive tried another battery as well
1598cc
Postby NZcelica » Fri May 06, 2005 12:05 am
definatly sounds like your altenator brushes and and some other things are stuffed, happens over time.
Get it rebuilt, only costs a little over $100 (chevettes one did anyway)
Matts theory above seems pretty conclusive actually, try a battery you KNOW is good.
ST165 Celica GT-4 <SOLD>
97 GT-T 18psi <GONE>
96 Carib BZ 5 speed
Looking to import a car? PM me
Lots of performance Toyotas forsale. PM me for details
NZcelica
Postby AJz » Fri May 06, 2005 1:51 am
^^^bang on what he said, as with anything old, sumtimes they just crap out.^^^
I had vtax :(
AJz
