FX-GT Exhaust upgrade???
Postby RickGT » Thu May 05, 2005 11:42 pm
any help on exhaust setups on my fx-gt would be great, i was thinking 2.25" pipe with a super large coby, then a stainless tip which is same size and stlye as a coby but just stainless??? any good?
would removing the cat be any help, im afraid that its going to be to loud, thats y i was thinking of leaving the cat in there
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby fx gt » Fri May 06, 2005 8:33 am
dont go huge stainless exaust,looks gay and everyone has em,i can sell you a end coby muffler if ya like,sonuds real loud but nice
fx gt
Postby RickGT » Fri May 06, 2005 9:22 am
yea nah thanks ill stick with the stainless, ive already bought it, its not huge anyway, jus the right size for my car
EP91 Glanza V
RickGT
Postby Lanius » Fri May 06, 2005 10:07 am
If you don't want to remove the cat, at least get it replaced. With the age of your car, if its still running the factory cat converter, it will be clogged and gummy, and probably more of a restriction than anything else in your exhaust. Freeing up the exhaust will help heaps.
You're on the right track with the 2.25" pipe (don't need any bigger than that unless going forced induction), through to resonator and muffler, but you might wanna consider two resonators to quieten the famous 4AGE "twang".
With that set up your car should perform a little bit better (removing the cat), and sound nice (2 x resonators).
Good luck :)
Lanius
Postby 86_rolla » Fri May 06, 2005 3:46 pm
yeh i got a coby rear muffler with a chrome tip, every muffler shop said it wld be loud azzzzzzz and then i finaly found a midas that wld put it on and its actually nt that loud, nice sound
86_rolla
Postby RickGT » Fri May 06, 2005 4:34 pm
so youve just got 1 coby in your exhaust and thats it?
EP91 Glanza V
RickGT
Postby quinny » Sun May 08, 2005 9:18 am
my 93 has a press bent 2.5" with over a metre of resonators and straight thru stainless boynut muffler which i have to swap with another bolt on cooper style one at the back to just get a WOF. its sounds mint but have learnt that shiney cannons do nothing but shine and grind away on our roads. Ditch cat, 2 cobys and big can on the back sounds mint, loud as without the 100kph drone, and another crap bolt on to keep the Wof man happy, i just got a 2bolt flange about where the axle line is
currently beating - AE101 Sedan, blacktop/6spd, tein coilovers, braided lines, cup holder, and every other bloody thing possible.
quinny
Postby RickGT » Tue May 31, 2005 5:05 pm
ive found two coby's, (1X 2 1/4" 19" $150) and (1X 2 1/4" 15" $50) is that resonable???:twisted: also with a 2 1/2 inch exhaust tip, would this be a good setup for my fx-gt???
EP91 Glanza V
RickGT
Postby fx gt » Tue May 31, 2005 5:20 pm
i could sell you a coby exaust tip,use to be on my fxgt and sounded great!
fx gt
Postby RickGT » Tue May 31, 2005 5:40 pm
is it just a normal coby, or has tip joint on it, as i have already got an exhaust tip
EP91 Glanza V
RickGT
Postby fx gt » Tue May 31, 2005 5:47 pm
looks like a normal coby but it has a longer tip on it
fx gt
Postby RickGT » Tue May 31, 2005 6:06 pm
what size? good condition? how long was it on yr car 4
EP91 Glanza V
RickGT
Postby RickGT » Tue May 31, 2005 6:08 pm
This look alrite???
EP91 Glanza V
RickGT
Postby fx gt » Tue May 31, 2005 6:11 pm
not sure about size and not sure about how longs its been on for as it came with the car but its in pretty good/used cond
fx gt
Postby RickGT » Tue May 31, 2005 6:16 pm
thanks neway, ive found some cheap bn 1s
EP91 Glanza V
RickGT
Postby lowridding » Tue May 31, 2005 6:20 pm
take out the cat and put a straight pipe through. ae92 have a good size pipe anyway.
used this for groupn rally.
If it aint broke, help it along.
To go fast is fine, to look good is ok, but only a fool tries to do both at the same time.
lowridding
Postby fx gt » Tue May 31, 2005 6:22 pm
with all those cobys its going to be bloddy loud
fx gt
Postby RickGT » Tue May 31, 2005 6:51 pm
well if i dont have cobys its going to be louder
EP91 Glanza V
RickGT
