urgent help please changing gear box oil
Postby shaggz » Tue May 10, 2005 4:32 pm
hey you'll jst doing a spot of maintance on my car, can anyone descreibe or has image of where drain plug/bolt for letting out gearbox oil on 4afe engine is(manual gearbox) and also the plug/bolt to fill it back up
drive it till it breaks, then upgrade it
Santa Edit: Steve is the former owner of a man-card
shaggz
Postby CozmoNz » Tue May 10, 2005 5:12 pm
thats the filler bolt. (smack bang in the center, look closely)
drainage bolt is on the bottom of the gearbox (90 degrees around from where that bolt is).
if you need more pix, gimmie a yell.
this is of a 4age, ae111 trueno. you can see the battery on the right, and the dizzy on the upper left
Rayne For President!
CozmoNz
Postby shaggz » Tue May 10, 2005 5:40 pm
can hardly make it out put if i have a look at mine ill probably see it all cheers
shaggz
Postby EVLGTZ » Tue May 10, 2005 5:45 pm
its a pretty huge but flatish bolt...hard to miss.
Prob 23mm from memory?
btw click on the pic...its gets bigger :)
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby CozmoNz » Tue May 10, 2005 6:01 pm
24mm
make sure you hold the socket against the bolt, you do NOT want to round those bolts off.
CozmoNz
Postby Twolitre » Wed May 11, 2005 12:50 am
And unlike myself in my earlier days, try not to tighten it back up with a breaker bar, even a moderate amount of force could eventuate in a new gearbox :wink:
Twolitre
Postby Santa'sBoostinSleigh » Wed May 11, 2005 12:31 pm
steve - doesnt help that you are a cabbage!
if you need a hand gimme a txt, i can see the bolt in the pic - click on it opens a link. right in the center
come pick up your jigsaw or its mine :twisted:
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby AutoGT » Wed May 11, 2005 12:48 pm
i think its this bolt...pretty much same on all yotas innit?
http://infraxion.net/alkaif.Pics/drainplug2fc.jpg
i've high lighted the bolt..should be easy...(i hope i high lighted the right bolt).
AutoGT
haha cheers all
Postby shaggz » Wed May 11, 2005 1:51 pm
i can see the drain bolt thats all sweet, is the fill bolt the one with the allan key slot in the top???????????
shaggz
Postby aesc » Wed May 11, 2005 1:55 pm
No,
Its the same type of bolt but just up higher on the gearbox
EX AE101 owner
2013 Ford Focus ST
aesc
cool cheers
Postby shaggz » Wed May 11, 2005 3:06 pm
and how much gearbox oil/fluid will it take i guess i should put the same amount back in as what came out??????
shaggz
Postby Mr Revhead » Wed May 11, 2005 3:30 pm
just fill till it reachs the bottom of the hole, a little dribble out is the correct amount. will be between 2.2 and 3.5 litres
as another note
Postby shaggz » Wed May 11, 2005 5:12 pm
2nd queery and main reason behind the fluid change,car has 168tho kay's on it now, the gearbox changes fine no hesitation typically notchy toyota box,but it is fairly noisey as in if im driving along without the stereo it stands out like a horses dong, i figured a fliud change wont hurt, but as i said it all works fine any other suggestions as to what it could be??
shaggz
Users browsing this forum: Bing [Bot] and 16 guests
