Closed vs Open Combustion Chamber - Fuel wieght.
Postby RedMist » Sat May 21, 2005 9:41 am
As a progression from Acesnipers thread, I was thinking of the attempt to keep fuel in suspension and wondered if fuel weight was a significant factor in determining wither or not to run a closed combustion chamber.
Avgas is significantly lighter than petrol, I would speculate that this is because it is madeup of shorter chain hydcarbons, again speculating, this should ensure a better fuel distribution through the charge and enable the fuel to carry further without puddling on the cylinder walls.
I wondered if anyone has any ideas on the speculation.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby RedMist » Sat May 21, 2005 10:48 am
My logic is flawed in regards to short chain hydrocarbons and density. But its most certainly a lighter weight fuel with higher octane rating.
RedMist
Postby Mr Revhead » Sat May 21, 2005 11:01 am
you boffin you.
maybe a thread on what closed/open chamber means maybe a better starting point! im sure a lot here would find it interesting.
Postby RedMist » Sat May 21, 2005 12:14 pm
Already there my fellow boffin friend....
viewtopic.php?t=31685
RedMist
