noob intake questions
Postby anthrax » Mon May 23, 2005 3:41 pm
Hi.
What exactly is this: (I know its dirty :) )
In my 92 celica gt
My guess is that it is some kind of sound muffling device?
My question is can I safetly take it off? The problem is if I take it off there is nothing left behind it, i.e. a straight hole to the pipe which would result in air bypassing the filter furthur down. Is there something I can cover the hole up with? Or maybe I am mistaken and I shouldnt take it off?
With it taken off:
Thanks.
anthrax
Postby Malcolm » Mon May 23, 2005 3:53 pm
it's an intake reasonator, why do you want to take it off?
btw, I don't suppose your celica has manual wind up windows does it? Just asking because it appears to have a 3sfe engine
Postby anthrax » Mon May 23, 2005 3:58 pm
Hi. No actually its a NZ New model 92 gt with a 5S-FE 2.2 litre engine, automatic windows. (weird ehh)
I just figured if I took it off it might change the sound a little (louder?) which would keep me content enough not to ruin it with a pod filter :D
anthrax
Postby AE85coupe » Mon May 23, 2005 4:39 pm
yeah will make it louder, but then you will risk getting shit up your intake, unless you block up the hole
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Emperor » Mon May 23, 2005 4:41 pm
So you can take the resonator off if you block the hole up?
Emperor
Postby AE85coupe » Mon May 23, 2005 4:45 pm
yeah man, its all good, some people think it may affect power a tiny tiny tiny wee bit on some cars, but i think thats a crock of shite haha
Details of car here
AE85coupe
Postby anthrax » Mon May 23, 2005 4:45 pm
okey dokey I'l take it off and see how it sounds, if I want to leave it off I'l block off the hole with something, any idea what?
anthrax
Postby AE85coupe » Mon May 23, 2005 4:48 pm
a piece of plastic cut out from the bottom an ice-cream container then glued/duct taped on
or is that a bit rugged hahahaha
Details of car here
AE85coupe
Postby anthrax » Mon May 23, 2005 4:56 pm
hahaha, i'l give it a go.
The plastic or duct tape wont melt or anything will it?
anthrax
Postby thaphatty » Mon May 23, 2005 7:37 pm
duct tape will be fine, had a old car of mines intake taped up for about 6 months, was still on perfectly afterwards
dont use electrical tape though because after ages it can go shitty
thaphatty
Postby KinLoud » Tue May 24, 2005 7:55 pm
This is a resonator.
It looks like it is between the airfilter and the throttle body - this means that it is there to help make more power.
If you take it out you will more than likely lose some power at one or several points in the rev range.
If you can try to fit a larger one there.
Do A Google search on Helmholtz - you will learn why it is there and how it helps make power.
Ken
Hamilton
021 408 863
Postby NA Drifter » Wed May 25, 2005 11:25 am
Yup, I 100% agree with Kinloud.
They are there for kinna "air reserve" for ur engine at certain rpm. From experiment, bigger are better. But too big, won't much different. So, the factory ones are optimal size and you don't want to go anything smaller than that. If it a daily driven car..(normal driving) probably you can't really feel anythnig different... mainly different are when the car is going hard/high rpm.
Also, there is no real harm to the engine to run without it as long as all the air going into the engine been filter. :wink:
Keith
NA Drifter
Postby bad20v » Wed May 25, 2005 11:51 am
I think Performance Car mag or Fast Fours did an article on this a while back. They tested different sized units on a n/a vehicle and dyno'd the car after each change. It was quite interesting to read. cant remember what issue it was or what mag.
Thank-You.
bad20v
Postby Mr Revhead » Wed May 25, 2005 12:06 pm
i agree, how ever some are there to cut down on noise.
Postby Stealer Of Souls » Thu May 26, 2005 9:31 am
bad20v wrote:I think Performance Car mag or Fast Fours did an article on this a while back. They tested different sized units on a n/a vehicle and dyno'd the car after each change. It was quite interesting to read. cant remember what issue it was or what mag.
Hot4s did this test. They found a bigger resonator improved lower end torque/power. It was on a mitsi mirage 1500 SOHC. They tried everything from a 600ml coke bottle up to a 5L container. According to their dyno the 5L container was very similar to a 2L (??) bottle and improved the low end by around 7% (not exact, I might look this up when I get home...) over no resonator at all.
'86 AE85.5 Levin
Stealer Of Souls
Postby AE85coupe » Thu May 26, 2005 10:21 am
wow thats really amazing, i take back anything i said about them mostly being pretty much worthless, i knew they affected power slightly but 7% isn't to bad
Details of car here
AE85coupe
Postby Mr Revhead » Thu May 26, 2005 10:41 am
remember every car will be different.....
some wont have any improvement at all... so theres no point rushing out and sticking one on your car!
Postby bad20v » Thu May 26, 2005 10:43 am
I suppose someones goin to try selling this on TradeMe now as :
* The Amazing 7% Power Increasing Device For Your Car *
* Buy Now For Only $99.95 *
* Easy Installation - Only takes 5 mins *
* Quality Plastic Coke Bottle Construction *
* Satisfaction Not Guaranteed *
Some poor fella would buy it.
Thank-You.
bad20v
Postby AceSniper » Thu May 26, 2005 12:02 pm
its called... ARC... Style... ARC intake chamber... good things ;)
AceSniper
Postby Stealer Of Souls » Fri May 27, 2005 9:38 am
Yeah. But 7% is from a really large container...
They found the best general result (space/size vs results) was from the factory one which was a bit more than 600mls or something.
And the car was a mitsi mirage with a grand total of 60kW or something like that. 7% is a lot for that car, but as stated, every car is different.
In fact they suggested that there could be better results found by using different shapes rather than volumes.
'86 AE85.5 Levin
Stealer Of Souls
