4agze in AE82
4agze in AE82
Postby dreama » Thu May 26, 2005 4:03 pm
Hey just wondering how hard this is. I know it will bolt in easily enuf, my questions are:
- Will the standard fueling system (i.e. fuel pump, tank, fuel lines) be ok with a standard engine.
- Will there be any wiring issues if i get just a standad ZE computer
- Will a new exhaust system be required or can i just have the flanges lengths changed so pipes meet extractors
Any help on these questions will be appreciated. And before anyone asks not to interested in making the engine more powerful would rather keep reasonably standard i.e. exhaust airfilter type mods. As this car will just be a run about.
Thanks in advance for any advice.
81 Alfa Romeo Sud Ti
89 Mitsubishi VR4
86 AE82 Corolla FXGT
89 Subaru Leagcy RS
82 TA63 Carina GT-T
89 KS13 Silvia
94KS14 Silvia
86 AE86 Levin
93 EG6 SiR B18CR
97 180sx Type X
(Current) Hunting for new ride.....
dreama
Re: 4agze in AE82
Postby Distrb » Thu May 26, 2005 4:16 pm
dreama wrote:Hey just wondering how hard this is. I know it will bolt in easily enuf, my questions are:
Fuel System im not sure about, but i would think you'd want to take care of this with standard GZE items to ensure its reliable..
There will be wiring issues as you need weed out your engine loom out of the rest of the loom, also you'll need to locate and hook up things like oil, alternator checklights etc also rev counter... so there is still a bit of work to do, even with the standard GZE computer.
Depending on how much of the ZE exhaust manifold and downpipe you can get your hands on will determine where you can reattach the downpipe to your standard exhaust. It will run fine... but probably not as well as it could
Distrb
Regular Poster
Postby dreama » Thu May 26, 2005 5:02 pm
O yea i understand all that but in a lot of cases you have to change plugs etc... to get things to fit.
Ive also been told to watch out for alternator locations etc... will i have to move any stuff so it will fit correctly????
89 Mitsubishi VR4
89 Subaru Leagcy RS
82 TA63 Carina GT-T
89 KS13 Silvia
94KS14 Silvia
86 AE86 Levin
93 EG6 SiR B18CR
97 180sx Type X
dreama
Postby Distrb » Thu May 26, 2005 5:07 pm
dreama wrote:Ive also been told to watch out for alternator locations etc... will i have to move any stuff so it will fit correctly????
As far as i know you dont need to move anything if you are using the ZE alternator.
Distrb
Regular Poster
Postby dreama » Thu May 26, 2005 5:23 pm
Kool. Sorry bout all the question as im sure theyve prob been asked a million times by other dreamas (no pun intended) like me. Im just figuring out what im guna do when i sell my S13 farkn uni chews up all my muny.
One more question while i think of it will the ZE LSD gearbox fit in the standard tunel with no mods?
89 Mitsubishi VR4
89 Subaru Leagcy RS
82 TA63 Carina GT-T
89 KS13 Silvia
94KS14 Silvia
86 AE86 Levin
93 EG6 SiR B18CR
97 180sx Type X
dreama
Postby Distrb » Thu May 26, 2005 5:57 pm
dreama wrote:Kool. Sorry bout all the question as im sure theyve prob been asked a million times by other dreamas (no pun intended) like me. Im just figuring out what im guna do when i sell my S13 farkn uni chews up all my muny.
there is no tunnel for the gearbox, its a FWD :wink:
Distrb
Regular Poster
Postby dreama » Thu May 26, 2005 6:21 pm
Yes i kno there is no tunnel, but couldnt think of better way to describe wat i was trying to say. Will it fit? using all the standard parts? Obviously not the slaves, cables, etc... but will the mounts etc... be fine?
Just trying to way up options between putting in supercharged engine or justing turboing the standard bluetop (and maybe later putting in the LSD gearbox)
89 Mitsubishi VR4
89 Subaru Leagcy RS
82 TA63 Carina GT-T
89 KS13 Silvia
94KS14 Silvia
86 AE86 Levin
93 EG6 SiR B18CR
97 180sx Type X
dreama
Postby THA SHZ » Thu May 26, 2005 6:44 pm
yes it will fit but the rear engine mount will not , if u want ne more info on it pm me as i have just done this in mine 8)
THA SHZ
Postby ChaosAD » Thu May 26, 2005 7:08 pm
Crossmember will have to be modified to fit the gze box, and if you use a later model gze with the DLI your factory tacho wont read the revs properly (aparently)
ChaosAD
Postby evil_si » Thu May 26, 2005 7:10 pm
you will need the ze wiring loom , and replace the one in the car with it. you cannot just plug the ze computer in and run it, the ecu pin outs are different,
you can easily fit and run the ze lsd box, but you need the ze cv's driveshafts and hubs, ae they are bigger.
evil_si
Postby dreama » Thu May 26, 2005 7:19 pm
Thanks for all the info THA SHIZ may get in touch with you if i decide to go ahead with the idea.
Yea there is a prob with the tacho wiring my friend had the swap done into an AE92 out at boostd performance and its never been able to show revs at all. He was told he'd need to some kind of current converter or something????
Any ideas on just turboing the standard engine
89 Mitsubishi VR4
89 Subaru Leagcy RS
82 TA63 Carina GT-T
89 KS13 Silvia
94KS14 Silvia
86 AE86 Levin
93 EG6 SiR B18CR
97 180sx Type X
dreama
