a/c light flashing
a/c light flashing
Postby fx gt » Thu May 26, 2005 5:37 pm
when i turn on the aircon for my fxgt (ae92) the a/c and econ button start flashing,what does this mean?
hope i havnt broken anything :P
fx gt
Postby dazzag » Thu May 26, 2005 6:58 pm
its means that there is a fault in the ac system. not sure exactly what the fault could be. i think it depends on how many times it flashes.
want a ae86, dont want to pay 8 grand for one
have to settle for my ae92
dazzag
Postby fx gt » Thu May 26, 2005 6:59 pm
dam,i better get it checked out then before i use the aircon again,im pretty sure it just keeps on flashing :?
fx gt
Postby dazzag » Thu May 26, 2005 7:02 pm
yeah its best to get it checked before you use it again.if you in wellington area i can give you a number for a ac specialist that is real good and has good prices
dazzag
Postby fx gt » Thu May 26, 2005 7:03 pm
nah im in auckz
fx gt
Postby matt dunn » Thu May 26, 2005 7:34 pm
The A/C ligh flashing means the sensor in the pumps has detected that the pump aint pumpin and is most likely stuffed.
I have seen this a few times and had it happen on my AE92.
Postby fx gt » Thu May 26, 2005 7:37 pm
where bouts is the pump situated?
fx gt
Postby dazzag » Thu May 26, 2005 7:41 pm
underneath the power steering pump.if you looking at the engine from the front of the car its on the bottom right side of the engine
dazzag
Postby fx gt » Thu May 26, 2005 7:45 pm
thanks,ill try all the fittings and stuff like that
fx gt
Postby Alex B » Thu May 26, 2005 8:24 pm
what do you mean try all the fittings? dont un attach it unles its stuffed, they arnt the cheepest to get refilled :?
Postby fx gt » Thu May 26, 2005 8:25 pm
ahh i c,just check nothing is unpluged etc etc,and ill check fuses
fx gt
Postby Alex B » Thu May 26, 2005 8:26 pm
yea check all that and do the revs go down a bit when you turn it on at idel?
Postby fx gt » Thu May 26, 2005 8:29 pm
fx gt
Postby Alex B » Thu May 26, 2005 8:35 pm
well if the revs go down it means the clutch is enableing. Maybe you got a gas leak?
Postby fx gt » Thu May 26, 2005 9:13 pm
yip the revs do go down,but how does that cause the clutch to enable?
fx gt
Postby Alex B » Thu May 26, 2005 9:16 pm
the a/c clutch not the trans clutch
Postby fx gt » Thu May 26, 2005 9:21 pm
hehehe woops:Pi know some one that has a dignoses(or how ever you spell it) so i may get them to plug it in to see whats going on:?:?
fx gt
Postby matt dunn » Thu May 26, 2005 11:58 pm
The light flashes cuse the sensor in the pump is not detecting pulses.
For this to happen the clutch must engage first for it to start to sense.
This means that the gas electric's and the a/c clutch are all fine.
The pump itself has worn out inside and cannot create enough flow.
The sensor is in the centre housing of the pump. Make sure it is plugged in. If it is, you need a new/second hand pump.
Matt
