Help! My GT-T auto gear box is dead!
Postby 6155 » Thu May 26, 2005 7:31 pm
Hi guys!
the auto gearbox in my 99 caldina Gt-T is dead!
It wont let me get in reverse + my 3 and 4 dead, when Im in 3 or 4 gear the rev just goes up!
what are my options? rebuild or just get a manual gearbox?
How much would it cost? how should I go to?
Thanks guys :cry: :cry:
6155
Postby fx gt » Thu May 26, 2005 7:39 pm
manuals are all ways good :P
fx gt
Postby dazzag » Thu May 26, 2005 7:44 pm
options are get and 2nd hand auto box and straight swap.or recondition your current one. reconditioning will be more expensive but more reliable then a 2nd hand one
want a ae86, dont want to pay 8 grand for one
have to settle for my ae92
dazzag
Postby beerad » Thu May 26, 2005 7:51 pm
go manual then you can launch mwaha
beerad
Postby fivebob » Thu May 26, 2005 8:18 pm
I presume you've checked the fluid levels?
It might not be the transmission, could be the computer or even just the relays.
As for a manual conversion, my advice is to forget that idea, theres a lot more involved like the ECU, clutch ABS/TRC/VSC computer and even the rear diff is different, besides the cost of the gearbox is going to be fairly expensive to begin if you can find one.
I have all the spare parts available that you might need to replace anything that's broken on yours for a reasonable price, came out of a '97 with 46k on the clock.
Postby blitza » Thu May 26, 2005 10:09 pm
hmm, I would rebuild, for reliability and future cost savings, and besides, you can launch an auto........
MAD Industries Limited
blitza
Postby Ae92typeX » Thu May 26, 2005 11:07 pm
yea, drop into a good trans service shop. as said above there are several things which may cause the issue- you dont wana change the box to find it was the ecu!
assuming of corse that fluid levels ahve been checked as well.
Ae92typeX
Postby 6155 » Thu May 26, 2005 11:59 pm
Thanks guys!
will take the car into a trans shop and get it checked out!
Any suggestion to which shop?
6155
Postby Ae92typeX » Fri May 27, 2005 12:06 am
Where you located?
Ae92typeX
Postby Inane » Fri May 27, 2005 11:34 am
Have you checked your ecu codes??
how / when did it die? what happened? describe circumstances..
I may be able to help.. I've done a bit of work on the electrics surrounding the ECTS in the GTT, and there is a "limp home" mode..
Inane
Postby 6155 » Sat May 28, 2005 1:56 am
hi guys!
I m in Auckland
it just happen. put it into drive as normal, 1st 2nd gear ok then 3rd the car started shaking and then the rev just keep going up, is like in a manual car you step on the clutch with out letting off the gas.
Then when i got to work, try to reverse and park. put it in R there is the reverse sound but no drive!
I am thinking of taking it to toyota to get it check out! is that a good idea?
:cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
6155
Postby Ae92typeX » Sat May 28, 2005 9:32 am
Yea, you could try toyota, or there is(/was) a few trans places up poana road and also around the onroad testing station. all of these are local to each other if you decide to go for a quote.
Ae92typeX
Postby beerad » Sat May 28, 2005 9:43 am
this sounds similar to what my mate did in his ford telstar he chucked it in reverse on the motorway by accident and reverse and 4th gear died.
beerad
Postby 6155 » Sat May 28, 2005 12:13 pm
Hello!
How do you go about checking your ecu code?
thanks alot guys
6155
Postby Adydas » Sat May 28, 2005 1:06 pm
by accident eh.. dont they normally have a button to stop such a thing happening.. the only way to do it would be to force it?
Adydas
Postby Silent Knight » Sat May 28, 2005 1:11 pm
Adydas wrote:by accident eh.. dont they normally have a button to stop such a thing happening.. the only way to do it would be to force it?
Nope...sometimes they can slip for some stupid reason. I did that in teh supra when I half toasted my second gearbox. Bent over to change channel on radio or something and accidentally brushed against the stick and it just went straight through to reverse :?
Needless to say there was alot of scary noises coming from gearbox... :lol:
Silent Knight
Postby Alex B » Sat May 28, 2005 7:09 pm
hm i did that in the old ladys 1500 pulsar it just cherpd the wheels killd the motor...Pulled over to the side of the road restarted the car and it went fine dam lucky for me from what im reading here...
Postby Inane » Mon May 30, 2005 10:06 am
my older sister did that in my dads beaten up old rolla,
110km/h in 5th into reverse.
lots of noise, back into 5th all good.
Inane
