ae101 mags onto ae92 rear strut issue
Postby quinny » Fri May 27, 2005 2:56 pm
I was wanting to treat my 101 sedan with some new wheels and throw my old 17's on the mrs ae92 GTi. problem. fronts mint but the mags hit the strut in the rear even with the spacer it already had with the current 15's. I Have spare 101 struts floating around but before i waste my time trying to swap the 92's for 101's can anybody tell me if they fit or what the solution is, cheers
currently beating - AE101 Sedan, blacktop/6spd, tein coilovers, braided lines, cup holder, and every other bloody thing possible.
quinny
Postby Rob_GTZ » Fri May 27, 2005 4:20 pm
just depends what the offset of the wheels is really, +40 is about as high as you can go on the back of an AE92, changing the struts will not change this.
Rob_GTZ
Postby Lloyd » Fri May 27, 2005 11:55 pm
Is it hitting on the strut itself or the spring seat? If its the seat you can just bash it in to fit with a hammer :)
Postby quinny » Sat May 28, 2005 4:29 am
Your not from Palmy Nth are you with technique like that, it rubbing the spring cup. is the dongy knocker method well proven?
quinny
Postby Lloyd » Sat May 28, 2005 5:07 pm
Well it was the guys at the tyre shop who did it to mine to make then fit. Said he had done it to a few to get them in there.
As long as your spring stays in and you're not going to have to bash it in HEAPS then give it a go.
Postby THA SHZ » Mon May 30, 2005 10:10 am
ae92 the highest in offset u can go is +35 , sum times u can just get a +38 on , but not a 40 without a spacer . And the wheel shouldn't be hitting the platform seat otherwise u r on the wrong size tyre as its changing ur rolling diameter 8) And as for putting the ae92 struts in there really aint no gain by doin tht and the strut wood effectively be in the same position .
THA SHZ
Postby Rob_GTZ » Mon May 30, 2005 7:44 pm
THA SHZ wrote:ae92 the highest in offset u can go is +35 , sum times u can just get a +38 on , but not a 40 without a spacer
No offence intended, but you're quite wrong there. A +40 definantly fits on the back of an AE92 without spacers, believe me, between my brother & I we've had about 6 sets of 17's on various AE92's, Levins, Truenos, FX's. At least 3 of these sets of wheels had an offset of +40.
If i didn't know it for a fact, i wouldn't have said it in the first place
Rob_GTZ
Postby THA SHZ » Tue May 31, 2005 9:53 am
dude no offence taken but i do this for a job and have fit many mags up to ae92 's and ae 82 's and u cant use a +40 p without a slight bit of rubbage and i own 2 of these so i should know 8)
THA SHZ
Postby Rob_GTZ » Tue May 31, 2005 10:01 am
well we'll just have to agree to disagree then, all i know is that the AE92 sitting in my bro's garage right now says your wrong, & the one I just sold, and the one i sold before that.
Rob_GTZ
Postby O2EAZY » Tue May 31, 2005 2:27 pm
well on my ae92 corolla sadan ive got 16's on there
the tyre r 195/50/r16 i need 3mm spacers on the rear to make them fit! i want 17's but not sure how im going to get them on !
bounce all da way home!:)
R.I.P 1990 toyota corolla sadan! lowered on 17's chromes n 1 week before getting paint she got stolen n writin off! thanks CAR THEFF! :(
its a sad day on da shore
O2EAZY
Postby THA SHZ » Wed Jun 01, 2005 5:10 pm
run a wheel with a +35 p offset and it will be fine 8)
THA SHZ
Users browsing this forum: Google [Bot] and 23 guests
