How to check for boost leaks
Postby beerad » Mon May 30, 2005 12:15 pm
Hey guys how do i check for boost leaks? spray the area in CRC and see if it bubbles?
beerad
Postby Ae92typeX » Mon May 30, 2005 1:28 pm
a thick mix of detergent (sg sunlight) may work better as crc does not always leave a layer on all surfaces
Ae92typeX
Postby vvega » Mon May 30, 2005 1:38 pm
car needs to be under boost to check for a pressure leack
you can however check for vacume leacks as they will most likely become boost leaks
block your intake so the car really has to suck hard to run and spray crc onto the pipe if the car revs up or the crc dissapears into the tube you have a wina
vvega
Postby beerad » Mon May 30, 2005 2:12 pm
the part im concerned about leakin is the blow off valve attachments. i can submesrse it in a ice cream container and see if it bubbles while boostin?
beerad
Postby vvega » Mon May 30, 2005 2:17 pm
how do you plan to achive that ??
v
vvega
Postby EVLGTZ » Mon May 30, 2005 2:22 pm
beerad wrote:the part im concerned about leakin is the blow off valve attachments. i can submesrse it in a ice cream container and see if it bubbles while boostin?
sounds interesting :lol:
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby beerad » Mon May 30, 2005 2:33 pm
with a stroke of prue genious
beerad
Postby Erelyes » Mon May 30, 2005 3:14 pm
Ever heard of waterlock? I wouldn't risk that.
Pete
JZX100 / Lancaster6
Erelyes
Postby beerad » Mon May 30, 2005 3:57 pm
true but it shouldnt be suckin water in should it cause the boost will be trying to escape
beerad
Postby Emperor » Mon May 30, 2005 4:01 pm
try it
Emperor
Postby Inane » Mon May 30, 2005 5:50 pm
the best way to check for boost leaks is to attach an unbuffered boost gauge (like an industrial pressure gauge for eg.)
if it varys wildly under consistent load then you have boost leak.
the other way of testing it would be to replace the piping you suspect is leaking and see if it makes a difference.
Inane
