AE92 FXGT clutch info please
Postby gmacrae » Wed Jun 01, 2005 10:47 pm
Hey people, im after a new heavy duty (1300-1400lb) clutch for my ae92 fxgt, couple of questions:
I've had a heavy duty daikin/exedy 4agze clutch before, this is the clutch i want for my fx (but the smaller 4age one of course). Its basically just a standard daikin clutch plate, with heavy duty pressure plate. Aparently this pressure plate isnt made anymore, and i've either got the choice of standard or daikin/exedy racing clutches, which would be completely overkill for a stock fxgt
Where can i get a real good deal on an uprated (1300-1400lb) clutch kit for this car without spending more than a few hundred backs?
What size is the clutch in this car? (ae92, redtop tvis/bigport) 200mm?
Thanks for any info guys - Gene
gmacrae
Postby Lloyd » Wed Jun 01, 2005 10:52 pm
You could get your old one modified. Got mine done through BNT, extra 50% clamping pressure on it and they modify the pivot points on the plate so it feels the same.
Postby gmacrae » Wed Jun 01, 2005 10:57 pm
I'd really like to replace the whole kit, just for the sake of being thorough, plus i had such a good run out of the last clutch in my mr2, shit it took a hiding.
I might swing by bnt tho and check out their prices. Anyone else know of a cheap place to get a decent clutch?
gmacrae
Postby Lloyd » Wed Jun 01, 2005 11:05 pm
Sorry, I should probably explain that better. The place they sent it to replaced the diaphragm spring in the pressure plate assembly and supplied a new standard clutch disc so you do pretty much get a brand new clutch.
Postby gmacrae » Wed Jun 01, 2005 11:08 pm
How much did you pay all up?
gmacrae
Postby Lloyd » Wed Jun 01, 2005 11:18 pm
Standard GZE clutch was listed as a heavy duty item already, got an extra 50% added on I think, so the pressure plate, clutch disc, release bearing came to about $500 I think. Nice having something that shouldn't slip unless you want it to and still have nice feel to it and be driveable.
Postby gmacrae » Thu Jun 02, 2005 12:09 am
I can get a standard daikin clutch (actually higher clamp than stock toyota) for about $340, which i dont think is a very good deal. I was hoping to get a heavy duty one for not much more than that. Last time i checked thats about where prices were
gmacrae
Postby gmacrae » Thu Jun 02, 2005 3:47 pm
anyone? can anyone tell me the clutch plate size? 200mm?
gmacrae
Postby gmacrae » Fri Jun 03, 2005 12:44 am
bump... :?
Can anyone tell me what size clutch my 87 ae92 fxgt will have? iv'e got quite a bit of conflicting information and need to buy a clutch so i can install it on the weekend
it's either 200mm or 212mm, anyone?
gmacrae
Postby ee904age » Fri Jun 03, 2005 8:31 pm
8"/200mm on a GE, 8 1/2"/212mm on a GZE
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Lloyd » Fri Jun 03, 2005 9:41 pm
So what about the 224mm GZE ones? ;)
