GZE Timing
GZE Timing
Postby CAMB01 » Mon Jun 06, 2005 11:56 pm
Hi all, this has probably been asked a million times before but how do i set the ignition timing on a 4AGZE with Distributorless ignition?
Basically i wanna know where to set the cam angle sensor and to what degrees before TDC to set timing once engine is running.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby CAMB01 » Tue Jun 07, 2005 8:00 pm
come on people someody must know
CAMB01
Postby Lloyd » Tue Jun 07, 2005 8:35 pm
Something along the lines of getting the engine running, bridge E1 and TE1 in the diagnostics box and check the timing with a light and adjust as you want. Remove jumper when done and that should be it.
Could be wrong, but thats how I think it went.
Postby CAMB01 » Tue Jun 07, 2005 10:39 pm
Thanks but i know how to do that what i meant was where to set the rotor??? inside the cam angle sensor.
CAMB01
Postby Lloyd » Tue Jun 07, 2005 10:47 pm
Turn the crank to 10°BTDC as you see it on the crank pulley and then put the Cam Angle Sensor in the hole so the pickup is pointing directly at one of the pickups and then play witht he timing from there. Pretty sure thats how I did it when I took the CAS out without marking it (stupid stupid me)
Postby matt dunn » Wed Jun 08, 2005 12:01 am
There is a proper procedure for fitting them.
same as fitting a dist a presume.
I have the info sheet but not here.
Something like,
turn the engine over until you can look through the oil filler cap and see the dot/mark in the cam signaling TDC no 1 compression.
Then there should be a mark on the shaft or toothed wheel of the dist that i think faced straight up.
I'll be back into the workshop tomorrow night so i'll grab the sheet.
Matt
Postby CAMB01 » Wed Jun 08, 2005 8:42 pm
Cheers Matt that would be great
CAMB01
Postby matt dunn » Fri Jun 10, 2005 1:10 am
Whats your email address and i'll send you a copy of the page.
Matt
Postby thaphatty » Sat Jun 11, 2005 1:45 pm
Just if theres anyone else that wanted to know..
2 dots, one on the cam angle sensor gear, one on the housing, goal is to get them to line up once fitted, so you have to turn the cam angle shaft back a bit because of the helical angle the gears on. make sure you start on 10 degrees before top dead.
pics
and what it should look like from the front (kinda, its off a small port but has the 4 wire cam angle sensor incoporated all the same)
thaphatty
Postby matt dunn » Sat Jun 11, 2005 8:54 pm
Here's a link to a page from the manual.
http://photobucket.com/albums/b20/MattD ... ccbdfa.jpg
Matt
Postby bluemaumau » Thu Feb 22, 2007 12:55 pm
great info in this guys, but how do i know were 10 degrees before tdc is? i know theres markings on the covers but thats after tdc isnt it?
Postby Crampy » Thu Feb 22, 2007 2:48 pm
bluemaumau wrote:great info in this guys, but how do i know were 10 degrees before tdc is? i know theres markings on the covers but thats after tdc isnt it?
Na, man, they're BEFORE top dead centre. Unless of course you've got a Honda motor in there (they spin the wrong way hehehe).
Crampy
Postby bluemaumau » Thu Feb 22, 2007 7:40 pm
i cant see the phattys pics anymore, but i dont have any cavitys on my teeth of the driven gear on my cas.
i do have a drilled hole on it tho
howevr which do i align it with? i have 2 drilled marks on the housing.+ a groove in the housing :? :?
it aligns best with the groove btw
also if looking at the crank pulley, the degree markings on the cam covers are on the RHS. isnt that ATDC??? if so how do i get 10 degrees BTDC!!!???
thanks all
Postby Crampy » Fri Feb 23, 2007 12:17 am
bluemaumau wrote:i cant see the phattys pics anymore, but i dont have any cavitys on my teeth of the driven gear on my cas.
thanks all
There should also be markings on the other side too. It normally goes to about 10 degrees after and about 20+ or so degrees before.
Crampy
Postby thaphatty » Fri Feb 23, 2007 12:57 pm
pmed
thaphatty
