back fire out inlet
back fire out inlet
Postby SIDE_FX » Fri Jun 17, 2005 12:02 am
ok looking a a rolla that back fires out its inlet has had head work so susapect cam timing out or bent valves anything else it could be ????? mixed up the cam shafts
SIDE_FX
Postby Akane » Fri Jun 17, 2005 7:09 am
check cam timings. Seen an evo with totally wrong cam timings backfiring out the intake before.
Postby deaf_rattle » Fri Jun 17, 2005 7:24 am
yeah timing might be out by 180degrees
My supra did this when we put the dizzy back in incorrectly :lol:
Postby l1ttle_d3vil » Fri Jun 17, 2005 8:41 am
mine done this when the dizzy wasn't wired up properly, even though the timing was perfect. then it carried on doing it even when the injectors weren't firing cos they had no power...everyone was telling me that "if its backfiring out the manifold the timing is out" when it wasn't that all along.
Postby ants_ae92 » Fri Jun 17, 2005 10:33 am
Cams cant get mixed up as the exhaust has the gears to drive the distributor, inlet doesnt. If they were mixed up it wouldnt go.
Check the timing. This will give you an indication on how far out it is if its the dizzy.
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby pc » Fri Jun 17, 2005 2:55 pm
Sounds like timing out by 180 degrees. Check for notch on inlet cam through oil filer hole to see if it's right.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby al_feinted » Fri Jun 17, 2005 6:38 pm
ht leads on wrong spark plugs?
Project cars: 83 corona tt142, 83 corona mark2 gx61, 82 avante chaser gx61.
www.toycrazy.net
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1408
al_feinted
Postby XS1V » Fri Jun 17, 2005 7:53 pm
Timeing definately out by 180degrees, had this when i put a new dizzy in one of my fx's just reset dizzy another 180 degrees through and you will be in action :)
ST205 Group A Rallye #2363
XS1V
timing???
Postby crispy'86 » Fri Jun 17, 2005 8:01 pm
Check the valve overlap aswell as the distributor det-up with timing!! Being an aftermarket cam grind the intake cam could be closing and the exhaust cam could be opening too early
crispy'86
Users browsing this forum: No registered users and 22 guests
