rounded botls!
rounded botls!
Postby fx gt » Sat Jun 18, 2005 3:22 pm
how the ***** do i get a rounded bolt of?ive tried everything
fx gt
Postby Psycho_Dad » Sat Jun 18, 2005 3:30 pm
depends on how hard the bolt is stuck in their, easy outs work sometimes, another method i use is i angle grind the rounded head into somthing i can grip... LOTS AND LOTS OF CRC
or if your a real skilled engineer dude, you can drill the whole thing out so the thread can be tapped out with a screwdriver... pretty impressive stuff really
peace
Psycho_Dad
Psycho_Dad
Postby adikt » Sat Jun 18, 2005 3:35 pm
gotta be careful with easy outs, they have a tendency to break sometimes.
which then leaves you with a superhard bolt you cant get out at all :?
adikt
Postby Rob » Sat Jun 18, 2005 3:40 pm
Where is the bolt stuck?
Vice grips tend to be the best
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby fx gt » Sat Jun 18, 2005 3:41 pm
the bolt on the end of the headlight :(
fx gt
Postby vvega » Sat Jun 18, 2005 3:41 pm
left hand twist drill bit
vvega
Postby Rob » Sat Jun 18, 2005 4:12 pm
You mean the one that connects it to the gaurd?
Could use a file to make a hex again then use a single hex socket, or if the headlight is being binned then just cut the head off with a hacksaw blade
Rob
Postby Akane » Sat Jun 18, 2005 6:20 pm
no matter what you do, DO NOT use easy-outs.
A left hand drill bit is what I suggest.
Postby B1NZ » Sun Jun 19, 2005 8:41 pm
yes and use a left hand hammer too :lol:
You could try welding a bit of metal on to the head, like a bar or something to use as leverage providing you have enough space to work it loose?
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby snwtoy » Sun Jun 19, 2005 10:36 pm
A file and some vice grips.. a headlight bolt can't be that big!
snwtoy
Postby pc » Mon Jun 20, 2005 11:17 am
vice grips on really tight and tap it with a hammer. Only works if there's lots of room though.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby pervert » Mon Jun 20, 2005 11:19 am
Thin angle grinding disk, grind a strip into the end and use a really big flat-head screwdriver...surely a headlight bolt can only be like a 12mm... :?
pervert
Postby vvega » Mon Jun 20, 2005 11:40 am
B1NZ wrote:yes and use a left hand hammer too :lol:
hehe the twist on a lft dril bit id the oposite way
so that means as you drilling..in reverce... the bolt will normally just undo as the drill takes the pressure off the locked threed
seems to work well..
v
vvega
Postby Jebus » Mon Jun 20, 2005 2:36 pm
Put a set of vice grips on it, and do that set of vice grips up with another set. Uber tight :D
Jebus
