angle you can have a driveshaft running at?
Postby Psycho_Dad » Sun Jun 26, 2005 5:40 pm
ok im sitting here staring at my project, noticing that the differential is substantially lower than the rear of the gearbox
what angle does the driveshaft have to be at if both the gearbox and diff are horisontal?
i hope this makes sense
Psycho_Dad
Psycho_Dad
Postby evil_si » Sun Jun 26, 2005 9:07 pm
yup there is a spec,
i have a digital angle for measuring this, but cannt remember what angle to aim for,
maybe call a d/shft shop and see what angles are recommended,
i dont helping you measure the angle,
another way is to measure the top of gearbox out put to top of diff input, and then from bottom of gearbox out put to bottom of diff input, the will be 2 different measurements, and there is a spec for the max it can be ax well. but i cant remember it. :?
evil_si
Postby Malcolm » Mon Jun 27, 2005 12:48 pm
A lot of homebuilt kit car/race car things that have the gearbox mounted next to the driver (ie where the passenger would be if it was a 2 seater), with a pretty short driveshaft going to the diff which is obviously in the center, and they have reasonably high angles on the shafts, so they normally replace the universal joints atleast once a season. I think that generally speaking the more angle you put on the shaft, the shorter the life of the universals, but too much and you will be running a huge risk of a universal failing and causing serious damage to the underside of the car, or even the top of the car, aswell as you if it causes you to roll! So yeah, definitely call a few driveshaft specialists :idea:
Postby Psycho_Dad » Mon Jun 27, 2005 2:35 pm
yeah i have called and they said i want less than 3 degrees... then i called the chevron guys and they said the same all fours said about universals wearing out, and the best thing to do is just mod the chasse till its low enough to be satisfactory... sounds CHEAP to me... bugger it
actually looks pretty easy to do, if i had the welding skills id be under their right now....
anyone else hear the money money money song in their heads? and how much should it cost to get a d/shaft setup? i got quoted $400 from 2 shops, if i supply both shafts :roll: :roll: :roll:
anyone know how much this should cost?
who wants to mount my engine/gearbox?
peace
Psycho_Dad
Psycho_Dad
Postby evil_si » Mon Jun 27, 2005 6:21 pm
$400 is pretty steep,
the one for the ke30, i supplied both ends and $230 and they gave me what i needed,
new tube and all? ill hunt out the receipts and see who i used,
i dont mind welding stuff up, cheap if its all prepped ready to go!!
evil_si
Postby Psycho_Dad » Mon Jun 27, 2005 8:53 pm
ok did a bit of calculating, its on a 10 degree slant, would that be illegal? hell if i have to change em every 6 months i dont care..... i just dont want to be cutting into my chasse too much
will i have to call a cerifier to find out?
Psycho_Dad
Psycho_Dad
Postby Malcolm » Mon Jun 27, 2005 11:50 pm
certainly wouldn't hurt to call a certer
Postby Psycho_Dad » Tue Jun 28, 2005 1:05 am
yeah just emailed one, wait to see what he says, i doubt it would be illegal no matter what the angle, unless it made some huge viabration or somthing... wait and see, thanks guys, hope this doesnt get too bad
peace
Psycho_Dad
Psycho_Dad
Postby edwagon » Tue Jun 28, 2005 6:05 pm
This probably won't apply to you in this case, but worth keeping in mind, universal joints do need to work at some angle (ie not zero) otherwise the rollers in the uni joints dont move and wear rapidly, "brinneling" i think its called, and that causes a whole other set of problems....
edwagon
Postby nite b » Tue Jun 28, 2005 6:29 pm
As edwagon said, keep the uni's working a little. Out of line a bit is fine,really want to make sure the tailshaft and diff-snout are parallel, dont try to 'point' the tailshaft directly at the diff, this can cause problems.
You may also find cert'ers may ask you to install driveshaft loop if running one-piece shaft.
Awesome deals on d/shafts? DriveInn(New Lynn) (09)827-2826, ask for Aiden, he will be the best & prob cheapest you will ever deal with.All our drift/race cars run his shafts.Have used others & they dont even compare!
Hope this helps,good luck with project :D
Convert Ltd
The conversion specialist
nite b
Postby Psycho_Dad » Tue Jun 28, 2005 11:21 pm
cheers guys, will call those d/shaft people tomorrow, ask them about angles and stuff while im their, i mean i can get it to about 7 degrees without having to cut the gearbox tunnel i think... hopefully that will be fine
thanks again guys
Psycho_Dad
Psycho_Dad
Postby suberimakuri » Thu Jun 30, 2005 6:53 pm
every single one of my conversions has had dshaft done by Drive Inn (Whibus), for a great rate. Never a problem, well recommended.
A++ in trademe speak.
suberimakuri
Postby MetalupYoAss » Sun Jul 03, 2005 3:51 pm
I used Beattys driveshaft shop in penrose for my hilux conversion. good product, cheap, fast turnaround, would deal with this trader again A+
MetalupYoAss
Postby Psycho_Dad » Sun Jul 03, 2005 4:15 pm
cheap? if i supply the ends they were gunna charge me $400+gst
i dont look at that price as cheap :cry:
peace
Psycho_Dad
Psycho_Dad
Postby evil_si » Sun Jul 03, 2005 6:48 pm
try driveshaft specialists,
they are in andromeda place in east tamaki.
evil_si
Postby MetalupYoAss » Sun Jul 03, 2005 10:04 pm
really? I gave them the original drive shaft, and hilux rear piece, they welded the hilux rear piece on and balanced it for like $130
MetalupYoAss
Postby matt dunn » Mon Jul 04, 2005 12:14 am
Apparantly from what the suspension set up place down here that is very good the nose of the diff should be 4 degrees down at the front,
Matt
Users browsing this forum: Google [Bot] and 17 guests
