engine light on st165
Postby SIDE_FX » Sun Jun 26, 2005 11:32 pm
just got my gt4 :D, turbos are cool 8O , but the engine light is on nd the guy said that it is because the intercooler pump is on const whicjh it is, i beleive him, have no reason not tooo :P, but is this actually tru ???
SIDE_FX
Postby vvega » Sun Jun 26, 2005 11:41 pm
yeap
:d
v
vvega
Postby NZcelica » Mon Jun 27, 2005 12:41 am
When the engine lights on, plug her into a diagnosis at an Auto sparky and see what comes up on the screen.
Actually have found this to be really useful in the past
ST165 Celica GT-4 <SOLD>
97 GT-T 18psi <GONE>
96 Carib BZ 5 speed
Looking to import a car? PM me
Lots of performance Toyotas forsale. PM me for details
NZcelica
Postby Malcolm » Mon Jun 27, 2005 12:39 pm
or you can just run a diagnostic check yourself by bridging Te1 and E1 in the diagnostic box, and reading the error codes from the check engine light on the dash. From memory you should get code 54? I think if the intercooler pump has been disconnected. Do a bit of a search for error codes to find the exact procedure (can't be bothered typing it up). Once you find the codes do a search on google or something (most Toyotas use the same codes), or post them up here and I'll look it up in my manual
when I say my manual, it's actually one I have borrowed for the last couple of years, thanks Tim!
Postby SIDE_FX » Mon Jun 27, 2005 4:09 pm
yeah he said it was running code 5 4 but will check again when hec gives me the man, fac ecus dont like more than 1bar i found out today :(
SIDE_FX
Postby Malcolm » Mon Jun 27, 2005 5:15 pm
you hit fuel cut? That's normal, not over one bar though, more like 12-13psi.
Postby matt dunn » Mon Jun 27, 2005 8:29 pm
yeah, st165 dont actually have a boost cut.
They have an air flow cut.
Guy down here built one as a race car. Used to cut at 12 -13 psi.
Put a big bore on it, then it cut at 10 to 12 psi,
and then put some cams in it and ported the head,
now it cuts out at 8 psi, LOL
Now he bring in in to me and says,
how the hell do you get around the boost cut?
Only solution is aftermarket ECU.
Matt
Postby Malcolm » Mon Jun 27, 2005 8:39 pm
or you could install and st185 ecu + loom. Uses most of the same sensors etc, should run the engine fine and allow more boost.
Postby matt dunn » Mon Jun 27, 2005 11:19 pm
The guy is being a tight ass.
I'd rather sell him my S/H link for a installed price.
Matt
Postby SIDE_FX » Tue Jun 28, 2005 12:15 am
yeah i didnt touch the boost it just spikes pretty bad :(
SIDE_FX
Postby Malcolm » Tue Jun 28, 2005 12:21 am
might have a faulty actuator or a leak on the turbo-actuator or actuator - t-vsv lines. Also the previous owner may have added some form of boost controller, especially if they've been playing with stuff like making the ic pump run fulltime etc
Postby SIDE_FX » Tue Jun 28, 2005 12:51 pm
oh yeah it has a tap but i havent been playing wit it so yeah i know taps a spike real bad, specially wen i cruisin at 2.5k and put my foot flat ity hits boost nd spikes
SIDE_FX
