Wtf? Handbrake light coming on
Postby rolla_fxgt » Mon Jun 27, 2005 2:28 pm
For some odd reason my handbrake light has started coming on when ever i accelerate or go round a corner. Does anyone know why this would be? It doesnt feel like the handbrake is actually engaged or engages when it comes on. Could it be a faulty sensor ?
Can i disconect it? its not like im gona forget the handbrakes on anyway, well except if i want to have it on, to "aid in cornering".
But its really starting to bug me seeing the damn red light comining on on the dash
rolla_fxgt
Postby Punter » Mon Jun 27, 2005 3:16 pm
correct me if i'm wrong but i think that means you brake fluild is low check the resovoir (sp), level will drop during cornering etc.
Punter
Postby pervert » Mon Jun 27, 2005 3:26 pm
I've seen a faulty sensor cause that to happen in a Primera.
pervert
Postby MrOizo » Mon Jun 27, 2005 3:27 pm
Punter wrote:correct me if i'm wrong but i think that means you brake fluild is low check the resovoir (sp), level will drop during cornering etc.
correct-o-mundo
MrOizo
Toyspeed Legend
Postby rolla_fxgt » Mon Jun 27, 2005 10:32 pm
the fluid level in the brake resivour seems within limits, & seems fine. is there a seperate rear cylynder or resivour?
Oh its an ae101 corolla fx gt, that will probally help aye.
rolla_fxgt
Postby XS1V » Mon Jun 27, 2005 11:03 pm
I had this happen in my fx, didnt really bother with it, but then when i changed my shocks and had to bleed the brakes, no more light so im guessing its something to do woth old fluid, low fluid in lines or something
ST205 Group A Rallye #2363
XS1V
Postby rolla_fxgt » Mon Jun 27, 2005 11:10 pm
Ive just had the rear track rods replaced, would they of disconnected the brakes to put them in, hence needing to re bled the lines & do a complete fluid replacement?
rolla_fxgt
Postby XS1V » Mon Jun 27, 2005 11:12 pm
they shouldnt have had to i dont think, if they had it would more than likely have stopped the light, thats if its not a faulty sensor of course
XS1V
Postby rolla_fxgt » Mon Jun 27, 2005 11:20 pm
It only seems to of happened since i got that done. Can i remove the sensor somehow?
rolla_fxgt
Postby Alex B » Mon Jun 27, 2005 11:23 pm
going dodgy/cheep on your breaks is not a reccomended thing
Postby XS1V » Mon Jun 27, 2005 11:26 pm
yea you can but its not good to do it, wof etc bleed your brakes first with new fluid since its always good to do anyhow and see what happens, how much is left on the brake pads themselves?
XS1V
Postby rolla_fxgt » Mon Jun 27, 2005 11:37 pm
ill check that tomorrow aye. Might be time for all new pads again & some proper brake fluid. ie not the cheap stuff midas uses
rolla_fxgt
Postby Alex B » Mon Jun 27, 2005 11:39 pm
dont go to midas, last i herd they didnt have a very good name in dunedin :?
Postby NZcelica » Mon Jun 27, 2005 11:45 pm
pyro_sniper2002 wrote:dont go to midas, last i herd they didnt have a very good name in dunedin :?
that is true! the did work on my SJ413 and i wasnt happy.
Your handbrake sensor is under the actual handbrake itself, take off the centre console and u'll see what I mean.
We had this problem on dads 80 series landcruiser and we just moved the sensor contacts further apart from eachother.
ST165 Celica GT-4 <SOLD>
97 GT-T 18psi <GONE>
96 Carib BZ 5 speed
Looking to import a car? PM me
Lots of performance Toyotas forsale. PM me for details
NZcelica
Postby rolla_fxgt » Tue Jun 28, 2005 12:00 am
Yeah im never going back there, i asked for hi temp front brake pads, which was all good, but they didnt think of putting good fluid in & put lesser than what was origionally in there.
Ill have a look at the contacts, i had a wee look when i had all the interior out of the car the other day, but i might give it full going over tomorrow.
If its pad related, anyone recomend a good highish temp pad, i tend to drive them quite hard, oh & what fluid too, is dot 4 gona be good enough? or whats in an ae101 fxgt as standard?
rolla_fxgt
Postby Alex B » Tue Jun 28, 2005 12:01 am
im pretty sure TRD do pads, email revhead.
Postby Quint » Tue Jun 28, 2005 1:56 am
I'm putting my money on the connections too, had the same problem with the connections in my supra, but it being tempremental it screwed alot more than just the light.
Look for little black 'connection' boxes, for some reason the japs love them, and they are useless, they get old and perish.
Quint
Postby Akane » Tue Jun 28, 2005 2:10 am
MrOizo, get rid of your 450k avatar/sig please.
Re: Wtf? Handbrake light coming on
Postby NA Drifter » Wed Jun 29, 2005 4:28 am
rolla_fxgt wrote:For some odd reason my handbrake light has started coming on when ever i accelerate or go round a corner.
Sounds like a born to be drift car to me...... or in it previous life?? ..cos it get use to having the light on during drift when the hand brake is pulled. :lol:
Keith
NA Drifter
Postby rolla_fxgt » Wed Dec 03, 2008 7:05 pm
Okay, its starting to do this again, but only under heavy throttle.
Other symptoms that I think are related is that it stalls very easily when reversing, after being parked for a bit.
Am I correct in assuming it might be sticky pistons or worn seals in the rear brakes? I only replaced the rear brakes late last year/early this year (and fronts early last year), so I don't think it could be time for new pads, and the fluid level looks pretty primo.
Any help appreciated. almost starting to think the cars a bit possessed :lol:
rolla_fxgt
