Will it pass a warrant??
Postby PJ » Mon Jun 27, 2005 4:39 pm
The panel at the bottom of my windscreen is rusted as f**k and looks like it has been for quite some time, but has been passing warrants. Question is, will it pass another one? I bought the car (86 Celica GT-R) at auction about a month ago n didn't notice the problem till after I'd taken possesion (yeh, dumbass, I kno...).
PJ
Postby Silent Knight » Mon Jun 27, 2005 5:56 pm
If it's structural or can have an effect on the rigibilaty (sp?) of the windscreen then no.
Silent Knight
Postby Caveman » Mon Jun 27, 2005 6:12 pm
If you own an old car you need to be fimilar with rust killer and bog.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby deaf_rattle » Mon Jun 27, 2005 6:16 pm
take it for a wof, fix it if it fails
Postby fangsport » Mon Jun 27, 2005 6:44 pm
get rid of the visable rust and apply rust kill.
what they can't see, they can't fail you on.
fangsport
Postby rallymazda » Mon Jun 27, 2005 7:20 pm
can you stick a screw driver through the rust? this is what we do to test it at work, it wont be as bigger problem if its in the middle as opposed to on the side by the A pillar
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby deaf_rattle » Mon Jun 27, 2005 8:16 pm
is the screw driver through the rust an ianz accredited test for rust? :roll:
if i saw anyone doin that to my car id give them the same test.
Postby 10k 20v » Mon Jun 27, 2005 11:26 pm
wof's are visual checks, which means no prodding panels with screw drivers or lifting panels etc.
10k 20v
Postby Lloyd » Mon Jun 27, 2005 11:36 pm
True, but if that was the case then surface rust would be failed.
If its just soemthing you can scratch off and have solid body under then its fine, if you can poke a screwdriver through then its failable.
Cant rememeber what the rules are around a windscreen. Rules are up on VTNZ/LTSA/whetevertheyarecallingthemselves site though
Postby Quint » Tue Jun 28, 2005 1:17 am
If its that black strip thing along the front of the windscreen then it wont fail, thats just a piece of lead(or something) just pull it off (pretty easy on that model if i memba) fix it up, and stick it back on. Remember rust spreads like the plague.
My brother had the same problem with his, i think... :/
Quint
Postby NZ_AE86 » Tue Jun 28, 2005 7:12 pm
If it is the black panel that is screwed on below the windscreen then it will pass a WOF. It is not structual 8)
NZ_AE86
Users browsing this forum: Google [Bot] and 19 guests
