4agze/Tvis
4agze/Tvis
Postby toyota111 » Tue Jun 28, 2005 8:03 pm
this maybe pretty stupid what im gonna say but has anyone tried to setup tvis butterflies on a ze manifold or does it already have it
toyota111
Postby Rick » Tue Jun 28, 2005 8:07 pm
None of the 4A-GZEs came out with T-VIS, doesnt mean you cant though
Postby RomanV » Tue Jun 28, 2005 8:10 pm
Well there is no point....
The idea of TVIS is to give an NA motor better intake velocity at low RPM... But you've already got a supercharger doing that for ya. :)
Its also restrictive at high RPM, which isnt cool. :(
Postby Rick » Tue Jun 28, 2005 8:13 pm
RomanV wrote:Well there is no point....
would the same apply if you had it turboed?
Postby Lanius » Wed Jun 29, 2005 9:50 am
The TVIS plates are partially closed at lower RPM to encourage better airflow, and more torque. As the RPMs increase, the plates open to allow the increased amount of air to flow easily. At a certain point, however, the plates themselves become a restriction to the airflow.
If you were to turbo a GZE, then theoretically, TVIS would give you improved low-down torque, but the TVIS plates would still be a restriction to the airflow once it gets up to higher revs.
Most worked 4AGEs / 4AGZEs / 4AGTEs that I've seen have all had TVIS removed.
Lanius
Postby Adamal » Wed Jun 29, 2005 9:55 am
To get the same amount of air through smaller runners mean that the air has to flow faster.
This helps with the low down in an N/A engine as the air is being sucked in. In a forced induction setup however, the air is being forced in, so it becomes irrelivent. :)
