How to tighten rear wheel bearing on BZG?
Postby Bling » Tue Jun 28, 2005 9:19 pm
hub is above, the two smaller holes are threaded, I need to get to the nut so I can tighten the bearing I hear, how is that done? I see no wat of getting to the nut :oops:
cheers for any advice
Postby NZ_AE86 » Tue Jun 28, 2005 9:40 pm
Not 100% sure as I have not done an AE111 rear bearing but earlier model corollas have the nut on the back and to get to it you must undo 4 bolt behind the hub and remve it.
NZ_AE86
Postby qik20v » Tue Jun 28, 2005 10:04 pm
check behind the threaded hole,
sometimes you have to put a small bolt into the holes and tighten them, then the bolts push the hub off
1996 AE111 Toyota Levin BZ-G - 15.1 @ 146km
http://toyspeed.blakjak.net/profiles/profile.php?id=301
qik20v
Postby AceSniper » Tue Jun 28, 2005 10:53 pm
the two holes are used to take the brake disc off, once its off there is a round disc behinde it (smaller) with a big hole in it... through that hole put a socket through it onto the bolts I think there is four... they all hold the hub on.
AceSniper
Postby Bling » Tue Jun 28, 2005 11:02 pm
AceSniper wrote:the two holes are used to take the brake disc off, once its off there is a round disc behinde it (smaller) with a big hole in it... through that hole put a socket through it onto the bolts I think there is four... they all hold the hub on.
So, the 4 bolts inside the hub, when tightened will sort the loose bearing?
Postby Rick » Tue Jun 28, 2005 11:23 pm
um, On my AE-111 you cant tighten the rear wheel bearing, I couldnt just replace the bearing because the bearing is part of the hub housing and is not repairable you have to replace the whole bearing housing
bzg
Postby crispy'86 » Wed Jun 29, 2005 7:13 pm
For all people for future reference.;
You can remove the hub from the car (provided the bearing isn't rumbly) undo the stake on the nut and tighten with a rattle gun. :twisted:
But this is strictly for a bearing that is loose only, if it's noisy it'd be recommended to replace it.
I've just finished working on Luke's car and that fixed the problem..
crispy'86
Postby Bling » Wed Jun 29, 2005 7:57 pm
hehe yeah, cheers for doing that Chris :lol: 8)
I'll know how to do it in the future :)
