hub is above, the two smaller holes are threaded, I need to get to the nut so I can tighten the bearing I hear, how is that done? I see no wat of getting to the nut
cheers for any advice
AceSniper wrote:the two holes are used to take the brake disc off, once its off there is a round disc behinde it (smaller) with a big hole in it... through that hole put a socket through it onto the bolts I think there is four... they all hold the hub on.
