excessive clutch travell
Postby fatgtr » Thu Jun 30, 2005 6:49 pm
hey there
got an aa report on a car. it stated it has excessive clutch travel. the pedal felt really easy to push. its a hydrolic clutch (im only used to cable clutches so it could be normal) also the clutch had been replaced 25,000km ago.
the aa report states the clutch engages at end of travel
how do i fix this
James
gotta love the punk music
fatgtr
Postby Malcolm » Thu Jun 30, 2005 7:06 pm
bleeding the clutch will help, but you can also adjust the travel at the pedal
Postby minijrocks » Thu Jun 30, 2005 7:12 pm
mine is the opposite. I was told when i got mine it had a new clutch put in. Mine engages really early, like before its 1/2 way to the floor but it bites really well and is easy to use.
minijrocks
Postby fatgtr » Thu Jun 30, 2005 7:22 pm
engaging the clutch is refering to releasing the pedal.
James
fatgtr
Postby minijrocks » Thu Jun 30, 2005 7:39 pm
sorry, i read it wrong. mine s similar to yours then. I wouldn't really worry about it, nothing has gone wrong with mine in the past 20,000 kms and i give it a fair bit of sh!t
minijrocks
Postby Mr Revhead » Thu Jun 30, 2005 7:41 pm
id say its nearly worn out......
Users browsing this forum: Bing [Bot] and 15 guests
