T-series diff into KP60
Postby Hachiroku » Mon Jul 04, 2005 9:41 pm
Hey there, just looking at the possibility of using a drum brake T-series diff in a starlet. What modifications are necessary to do this? I have access to a welder etc. I'm thinking about a 4age conversion and want a diff that's stronger than a k-series but cheaper than a disc brake T-series. Thanks :wink:
Hachiroku
Postby fangsport » Mon Jul 04, 2005 11:00 pm
it would depend if you want to run it as the 5-link set-up as per the diff, or the 4-link set-up as per the starlet. it is something me and Chang are looking to put into the KP 60 club car as the 4ag has already killed a diff( diff may have been on the out, though). as it isn't road registered, i'm thinking along the lines of putting the equal length trailing rods with panhard.
you would need to go to a FWD offset wheel or open the guards up a bit due to the extra width.
fangsport
Postby 92GTApex » Tue Jul 05, 2005 2:51 am
T-series diff being out of which vehicle sorry?
At the moment where looking at putting a diff out of tt14x corona into a kp62
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby Hachiroku » Tue Jul 05, 2005 11:20 am
TE71 corolla (not GT, they've got discs), heaps of old corona's, celica's etc. Isn't tt14x IRS? And how tricky is it to shorten a diff?
Hachiroku
Postby z|gen » Tue Jul 05, 2005 12:18 pm
i thought the te71(non lsd, drum brake) came out with the S series diff? and the T series was out of the celicas? :S
AE91 SUPERCHARGED COROLLA
z|gen
Postby fangsport » Tue Jul 05, 2005 1:30 pm
z|gen wrote:i thought the te71(non lsd, drum brake) came out with the S series diff? and the T series was out of the celicas? :S
yes, i was jumping the gun there. the diff we are probably using is in fact an 'S' from TE71 2T pushrod , not the 'T' from the 2TG version. same dimensions except the diff head size.
fangsport
Users browsing this forum: Bing [Bot], Google [Bot] and 18 guests
