how many km does 95 levin 's cambelt lasts?
Postby caslaelda » Tue Jul 05, 2005 8:15 pm
I v got a 95 levin on 130Kkm, it's still runing on the stock cambelt without any problem. but some ppl tell me that i need to change cambelt every 100k while some say it will last at least 150K. just wounder how many km it real lasts, coz i m pretty poor and change cambelt costs me alot ><
caslaelda
Postby Crimson Tears » Tue Jul 05, 2005 8:18 pm
As far as I am aware all Toyota cambelts are recommended to be changed at 150,000km for New Zealand new vehicles and 100,000km for import vehicles.
Crimson Tears
Postby Chelles » Tue Jul 05, 2005 8:18 pm
If in doubt call your local Toyota service agent. They are really the only ones who can answer a question like this with accuracy.
'96 RS Mirage Race car... (and when I'm a good girl; EVO 1!!) 2014 Toyota Hilux - daily driver!!
Gone but not forgotten: Race car AE85.6 Levin, AE101 Trueno, 84 MR2 AW11, 94 MR2 SW20, SR coupe KE35, AE92 FXGT, AE91 FXZS...
Chelles
TS Original Member
Postby CozmoNz » Tue Jul 05, 2005 8:24 pm
last i heard, mine snapped at 77,000km's
thus the reason why it was changed.
this is what the chaps up at the local mechanics said anyway... them doing it to the car before i brought it.
Rayne For President!
CozmoNz
Postby nz_baddass » Tue Jul 05, 2005 8:49 pm
on average every 100,000 km's , i change mine every 80,000 km's as its better to spend $200 then $2000 geting new valves ext
nz_baddass
Postby caslaelda » Tue Jul 05, 2005 8:57 pm
thx lot for the replys
caslaelda
Postby minijrocks » Tue Jul 05, 2005 10:06 pm
what happens if its got a timing belt sticker but you dont know the reliability of the kms? then your kinda fkd. Do you reckon this is why heaps of imports come in with cambelts done at 60kms? because they were on about 80-90 but wound back and then done the cambelt so it doesn't snap at 65kms?
minijrocks
Postby Lloyd » Tue Jul 05, 2005 10:36 pm
If you get a new car and aren't sure of the mileage then its probably worth doing it anyway, just like doing all the fluids and things when you get a new car.
Do them before 100,000 whatever car it is, some (not toyotas) are recommended to change every 60,000kms.
Had a Celica in the other day, 3S-GE which hadn't had a belt done for 135,000kms. Car still ran fine and everything, but inside the timing covers the belt was breaking up on the edges to the point where there was only about 3/4 of the original belt still on there and it looked like a sheep had been caught up in the timing gear with the amount of fluff and crap that the missing bits of belt had given off. That fluff along with a leaking water pump meant that there was a buildup on all the timing gears and idlers which was slowly wearing away at the teeth on the cambelt too. Wasn't too far from letting go completely.
If in doubt, change it.
Postby Leon » Wed Jul 06, 2005 11:33 am
Hmmmm, well, $25 + gst + fitting for a cambelt ... easy decision there.
Postby Caveman » Wed Jul 06, 2005 12:07 pm
If the car is a stock 20V and you snap the cam belt the valves will not bottom on the pistons.
A mate snaped a cam belt on his 20V. Was fine after a new belt.
Probably best just change it now, instead of worrying about $100 dollars. If your worrying about $100 you shouldnt own a car.
Or you can drive it till it snaps, which will end up costing you more because you need to add the price of a tow truck.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby TRD Man » Wed Jul 06, 2005 12:22 pm
We used to change them on our stock at 90,000km.
Many of the service stickers showed the Japanese owners were changing them at around this mileage so we figured it was probably the recommended time.
Remember too, that not only mileage, but age is a factor in deterioration of rubber components. We once had a genuine 10,000km AE101 Levin that looked & drove like new but on inspection the cam belt was quite severely cracked through age.
TRD Man
Postby Mr Revhead » Wed Jul 06, 2005 12:59 pm
100k or 5 years
if its a black top ALWAYS replace the auto tensioner
Postby blackie » Wed Jul 06, 2005 1:04 pm
130,784.345 km
just change it.
blackie
Postby CozmoNz » Wed Jul 06, 2005 1:23 pm
.345? how the hell do you get as accuriate as that?
unless you *trip meter* hasnt been used...
ever....
CozmoNz
Postby Caveman » Wed Jul 06, 2005 2:16 pm
CozmoNz wrote:.345? how the hell do you get as accuriate as that?
ever....
I agree with you for once
How did you get the odometer to the metre lol
AW11 Track Toy
Caveman
Postby sergei » Wed Jul 06, 2005 9:46 pm
BTW Blacktops will bend the valves if cambelt snaps, unlike most petrol toyota wich do not bend the valves if cambelt snaps.
Postby CozmoNz » Wed Jul 06, 2005 11:14 pm
u sure they are interferance?
mine snapped and mine still whops silvertops good >D
CozmoNz
Postby Adamal » Wed Jul 06, 2005 11:19 pm
Leon wrote:Hmmmm, well, $25 + gst + fitting for a cambelt ... easy decision there.
YOU'VE obviously never changed a cambelt on an SW20 before :P
Postby sergei » Thu Jul 07, 2005 12:43 am
When I was doing cambelt on a blacktop, if I would turn the crankshaft by hand, while belt was off, it would turn only ~270 degrees back and forth, + there are no cut outs on pistons for intake (?) valves
probably you were lucky that the camshafts stopped where they stopped, otherwise you might had bend valves, damaged pistons/conrods...
Postby CozmoNz » Thu Jul 07, 2005 1:21 am
Yeh...
wasnt me who had it snap on though, was the last owner, the mechanic chaps that did the cam belt told me (i did work exp there), seems odd though aye... low km's (well, sort of) and it snaps..
oh well shit happens, still going hard though.
CozmoNz
Users browsing this forum: Bing [Bot] and 20 guests
