Auto Levin not changing gears!?!
Postby F360 » Thu Jul 07, 2005 6:56 pm
Got a 1997 Auto Levin which seems to have trouble going to second gear sometimes. It mainly occours the first time you drive the car each day.
instead of clicking into second it will rev high causing me to slow down, then waiting for it to change. (of if it doesnt , pullover)
Any advice would be awsome.
Thanks
F360
Postby Lloyd » Thu Jul 07, 2005 7:00 pm
Checked how much trans fluid is in it?
Postby F360 » Thu Jul 07, 2005 7:17 pm
Nope, I'll learn to do that tommorow.
F360
Postby Adydas » Thu Jul 07, 2005 7:40 pm
Thermostat?
Doesnt that effect the auto box via the ECU somehow?
Something to do with the Engines temp ie when when its cold or the first time it does it.
Adydas
Postby Ae92typeX » Thu Jul 07, 2005 10:40 pm
does it flair at all at other times at all or just startup?
Ae92typeX
Postby Just_Juzz » Fri Jul 08, 2005 10:39 am
Trans Fluid, clutch pack may also be worn / f'd
Current Ride: 1998 Caldina GT
Me, me, me, me.....
Just_Juzz
Postby F360 » Fri Jul 08, 2005 6:33 pm
Ae92typeX wrote:does it flair at all at other times at all or just startup?
Mainly startup, but has occured other times, like taking off at lights etc
Thanks for all the ideas.
F360
Postby Ae92typeX » Fri Jul 08, 2005 11:11 pm
if the levels etc end up looking ok, there are some additives you can put in which help a lot. The best one, cant recall the name at the moment, I have not seen in any shops, but the supplier sells to dealers for cars they get with probs. If you dont sort it, ask me then and I will find out what its called (brain shutting down for week)
Ae92typeX
Postby F360 » Wed Jul 20, 2005 6:10 pm
Ae92typeX wrote:if the levels etc end up looking ok, there are some additives you can put in which help a lot.
Ive check the trans fluid and filled it up, but its still happening. Can you remember this products name?
F360
Postby minijrocks » Wed Jul 20, 2005 6:55 pm
does it not stay in the highest gear on the motorway when cruising? like jumps in/out of gears?
minijrocks
Postby evil_si » Wed Jul 20, 2005 7:00 pm
there should be a filter in the auto trans sump. you have to remove the sump to get to it.
no point just changing the atf if you dont change the filter.
when you changed the fluid what was the colour / condition.
bright red
brown
dark brown
what did it smell like? burnt?
there are transmission shops and garages that flush the system, to make sure there is no shit blocking it.
evil_si
Postby Ae92typeX » Wed Jul 20, 2005 9:56 pm
as said above, I would try fresh fluid and filter first, but, the product I was talking about is called 'shudder fix'. Comes in a small red tube. Im not sure if its availabe in any shops, but a lot of dealerships use it in their vehicles which may suffer from a bit of flairing.My mates old work used to order it through someone. Ive experienced it used, and it made a massive difference. But yea, best to try with fresh fluid and filter first.
Ae92typeX
Postby sergei » Wed Jul 20, 2005 11:49 pm
Hmm we use "shudder fix" for fixing 4wd binding in Subarus..
There is a "Lucas" aditive "Trans Fix"... I think supercheap sells it.
Postby Ae92typeX » Wed Jul 20, 2005 11:59 pm
sergei wrote:Hmm we use "shudder fix" for fixing 4wd binding in Subarus..
Yea, they used it a lot for that also- works well
Ae92typeX
Postby rustirolla » Thu Jul 21, 2005 9:40 am
i had same prob in my car and it turnd out the whole trans box and gone and i needed a new one :(
Previous Toyotas:
1985 Toyota Corolla GL
1990 Toyota MR-2
Current ride:
1991 Toyota Levin
:mrgreen:
rustirolla
Postby Bazda » Thu Jul 21, 2005 1:20 pm
My mate had this prob, the speed sensor on the box was broken or something, but the speed still read correctly.
sounds exactly like ur prob.
Users browsing this forum: Bing [Bot] and 16 guests
