ChaosAD wrote:Also note that 14psi from a turbo will make more power than 14psi frm a Sc
flygt4 wrote:the size of a turbo will also greatly affect the power..
ie running only 15psi mine managed 175kw atw..
plenty more left in it once i get get more fuel+boost in. go the turbo option , and select your turbo wisely for the application.
IH8TEC wrote:flygt4 wrote:the size of a turbo will also greatly affect the power..
what turbo you got man?
terrytuffguy wrote:Matt looks like you need an external wastegate if you ain't got one allready. By the way at what RPM is your peak power?
Users browsing this forum: Google [Bot] and 17 guests
