4agze/ 4agte Dyno Results Please
Postby no_8wire » Tue Jul 12, 2005 11:16 pm
I am currently investigating potential modifications to my car, and thought I would ask what other have done/ what results they have got?
1st, 4AGZE running a 12psi pulley....
2nd 4AGTE running ..(14?)..psi boost...
3rd 4age Stock Redtop running a SC12 with 8psi
no_8wire
Postby EVLGTZ » Wed Jul 13, 2005 8:28 am
goto the garagedori website, plenty of dyno charts there for 4ages, 4agtes and 4agzes.
From my own personel experience I can only provide you with an estimate of power on 14psi as have not dyno'd it on that level of boost. Would expect around 160kw at wheels given that 18psi gives 188kw
Hope that helps
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby aesc » Wed Jul 13, 2005 9:07 am
Mine dynoed at 107kw on 9psi, so im expecting atleast 120kw with the 175 pulley (13psi)
EX AE101 owner
2013 Ford Focus ST
aesc
Postby ChaosAD » Wed Jul 13, 2005 5:07 pm
Also note that 14psi from a turbo will make more power than 14psi frm a Sc as the sc drains quite a bit of power
ChaosAD
Postby EVLGTZ » Wed Jul 13, 2005 5:23 pm
ChaosAD wrote:Also note that 14psi from a turbo will make more power than 14psi frm a Sc
hell yeah I made 131kw with turbo on same boost as I did with 87kw with the s/c 8O
EVLGTZ
EVLGTZ
Postby evil_si » Wed Jul 13, 2005 10:18 pm
4agte with compression down to 105 psi per cyl,
on 11psi made 181hp atw
cant be bothered equating to kw.
evil_si
Postby Mr Revhead » Wed Jul 13, 2005 10:58 pm
or 4agze on sc14 8)
Postby 1goodidea » Thu Jul 14, 2005 9:33 am
aesc wrote:Mine dynoed at 107kw on 9psi, so im expecting atleast 120kw with the 175 pulley (13psi)
really, seems alittle high for a SC
1goodidea
sc..
Postby Fandango » Thu Jul 14, 2005 10:16 am
Remeber most lose power after 5000 rpm, some dont tho :)
Fandango
Postby aesc » Thu Jul 14, 2005 11:22 am
Yip may seem high but I have proof 8)
And it still lost power at 5500rpm, quite badly too. I think the power figure at 7000rpm was something pathetic like 45kw :lol:
EX AE101 owner
2013 Ford Focus ST
aesc
Postby beeker » Thu Jul 14, 2005 9:49 pm
If it helps I made 98kw at the wheels at Torque Performance with my AE101 4AGZE powed AE86. Sucking hot air though. Stock ECU / pulley etc.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby flygt4 » Thu Jul 14, 2005 10:09 pm
the size of a turbo will also greatly affect the power..
ie running only 15psi mine managed 175kw atw..
plenty more left in it once i get get more fuel+boost in. go the turbo option , and select your turbo wisely for the application.
flygt4
Postby gdsup » Thu Jul 14, 2005 11:54 pm
t p dyno, 4agze standard ecu and pulley, sc12, 122kw at 10 psi, check the graph to see the power peaks just before rev cut
http://www.garagedori.com/tech/dynos/4agze/tim_btblock_feb04.jpg
gdsup
Postby IH8TEC » Fri Jul 15, 2005 4:33 pm
flygt4 wrote:the size of a turbo will also greatly affect the power..
what turbo you got man?
Postby flygt4 » Fri Jul 15, 2005 8:18 pm
ihi vf24 (ballbearing) off a V4 STI.. still within reasonable limits for daily driving.
td05's and gtir t28's seem to net similar results as well. i think any bigger and you are just getting too big for the 1600 to make usable on the street.
i would have graphs to post but my tuner forget to get them for me. :roll: if this post is still going when i get a proper highboost run in a few weeks ill post those graphs :D
flygt4
Postby 3T-Rona » Fri Jul 15, 2005 11:28 pm
ive a m8 who has a gze running 180kw....... dnt ask q's cos i hav no idea hw....
3T-Rona
Postby matt dunn » Sat Jul 16, 2005 1:11 am
Here is a link to one of my dyno sheets.
20V turbo 4AGE
http://photobucket.com/albums/b20/MattD ... esults.jpg
Matt
Postby terrytuffguy » Sat Jul 16, 2005 1:14 pm
Matt looks like you need an external wastegate if you ain't got one allready. By the way at what RPM is your peak power?
My 4AG powered starlet puts out 227rwkw & 12.39 @ 115mph........ YEA RIGHT, Tui.
terrytuffguy
Postby matt dunn » Sat Jul 16, 2005 11:06 pm
terrytuffguy wrote:Matt looks like you need an external wastegate if you ain't got one allready. By the way at what RPM is your peak power?
Yes it's on the wish list.
Limiter is at 8500 so I think that is the end of the scale?
Postby MR2SIK » Tue Jul 19, 2005 9:36 pm
my standard gze made 104.5kw atw, and it was making power til redline
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Users browsing this forum: Bing [Bot] and 30 guests
