ok when i turn my wheel its all good then it gets really hard then clicks and does this twice on the way from dead centre to full lock (i guess once every full turn) and am kinda worried bout it since it does spin back thus could end in a crash, any ideas, the noise come from under the steering shaft surround, is a PS have checked to see if belt has come off and appears not to have
So is it when you turn the wheel or is it when you've already turned the wheel and you're moving?
