Boost
Boost
Postby CAMB01 » Sat Jul 16, 2005 11:29 am
Hey all, ive finally got my GZE running in my FX, but when i gas it the boost guage reads 5psi, then later on in rev range it goes straight to full boost 8psi in 1st gear, 10psi in 2nd, 11.5psi in 3rd, 13.5 in 4th.
This concerns me, as i'm running standard pulley, standard intercooler etc.
I don't have a tacho wired up yet, but when it hits full boost, there aint many revs left before i hit the limiter. Its running bluetop cams if that helps. its like having a really laggy turbo.
The long block is from an AE101, and the supercharger is from an AE92.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby CAMB01 » Sat Jul 16, 2005 8:20 pm
bump
CAMB01
Postby Bazda » Sat Jul 16, 2005 9:37 pm
13.5psi seems very high for standard pulleys...
Postby Adamal » Sat Jul 16, 2005 9:48 pm
Seeing as the boost is directly related to the rev speed, sounds to me like there something wrong with your gauge
Postby CAMB01 » Sat Jul 16, 2005 9:59 pm
Adamal wrote:Seeing as the boost is directly related to the rev speed, sounds to me like there something wrong with your gauge
Nope, coz i can feel it kick in, say i'm in 2nd gear, it'll sit at 5psi then as the revs get up to bout 6500rpm it shoots to 10psi
CAMB01
Postby IH8TEC » Sat Jul 16, 2005 10:44 pm
belt tight?
Postby CAMB01 » Sun Jul 17, 2005 12:43 am
IH8TEC wrote:belt tight?
YES.
I've just hooked up my tacho and at exactly 6000rpm in every gear it goes straight to full boost, sits at 3 - 5 psi before that.
CAMB01
Postby vvega » Sun Jul 17, 2005 9:20 am
superchargers $&#$%
v
vvega
Postby CAMB01 » Sun Jul 17, 2005 12:53 pm
vvega wrote:superchargers $&#$%
v
I don't think so.
It has to be something electrical, as it boosts at 5psi below 6000rpm, then the instant it hits 6000rpm the boost shoots straight to high boost depending what gear i'm in.
CAMB01
Postby vvega » Sun Jul 17, 2005 1:00 pm
ethier that or a abv
so do tell me how do you think it limits boost ???
you have 3 options
one the abv valve
2 you have a whol but that would be unlikely
or 3 supercharger is rooted
they are on or off there is no slipping option
they are directly coupled to the engine when locked so @ 6000 rpm eather the rotors are going fast enought to seal or your abv is puled up wrong
take ya pick
v
vvega
Postby CAMB01 » Sun Jul 17, 2005 2:33 pm
vvega wrote:ethier that or a abv
you have 3 options
one the abv valve
take ya pick
v
I'm thinking its the ABV.
But i plumbed it up according to the diagrams i got from toyota.
Could the bypass valve be rooted?
What if i bypass the ABV completely?
CAMB01
Postby vvega » Sun Jul 17, 2005 5:09 pm
bypass is a good mod and will give you all it will do
if it fixes it your will ber fine
v
vvega
Postby CAMB01 » Mon Jul 18, 2005 12:09 am
This might sound stupid, but i was looking at a diagram and a thought occured to me. Could ABV not be sealing properly, and is leaking boost back into circulation into the supercharger, where my boost guage can't read it as it is plumbed off the manifold.
But for some reason it seals from 6000rpm so i get all the boost going into the engine.
Just a thought, plz no bad comments.
I'm gonna try the ABV mod and see what happens
Cam
CAMB01
Postby CAMB01 » Mon Jul 18, 2005 11:50 pm
boost
CAMB01
Postby kpimpin61 » Tue Jul 19, 2005 9:59 pm
get a RWD... problem fixed
haha u love it cam!
kpimpin61
Postby CAMB01 » Thu Jul 21, 2005 7:36 pm
I've done the ABV mod and has given me 2 extra psi below 6000rpm, so instead of sitting at 5 it sits at 7psi till 6000rpm then goes straight to 10 - 12psi.
I don't really notice it as much now.
CAMB01
