Hey people, anyone ever put a 20V head on a GZE block with a turbo and had issues with the TPS (using the 20V TOS here as the GZE one spins the other way)?
With it plugged in there seems to be a fuel cut or something once positive pressure comes on. With it unplugged I can boost as high as the ECU can handle but then after a little while the engine cuts out and wont fire until the TPS is plugged back in.
Any ideas?
