by RedMist » Fri Jul 22, 2005 7:20 pm
Its all to do with acceleration. Which can be a combination of duration, lift and the lobe profile.
For instance a 310 degree 9mm lift cam MAY work (although I doubt it) where as a 270 degree 9mm lift cam MAY NOT work.
Hence you need to check with your cam grinder.
These aren't Franklin cams bought off VVega are they?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
