20v valve springs
20v valve springs
Postby AceSniper » Fri Jul 22, 2005 4:45 pm
what is the limit that stock valve springs can take? iv been told 9mm lift (re grinds) would prolly need new springs? but I want to be sure coz of the cost :oops:
AceSniper
Postby ChaosAD » Fri Jul 22, 2005 5:03 pm
ask your cam grinder. can you get the 20v cams reground to 9mm?
ChaosAD
Postby AceSniper » Fri Jul 22, 2005 5:30 pm
well the specs I have work out to 9mm guess its possable with shims....
AceSniper
Postby RedMist » Fri Jul 22, 2005 7:20 pm
Its all to do with acceleration. Which can be a combination of duration, lift and the lobe profile.
For instance a 310 degree 9mm lift cam MAY work (although I doubt it) where as a 270 degree 9mm lift cam MAY NOT work.
Hence you need to check with your cam grinder.
These aren't Franklin cams bought off VVega are they?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby vvega » Fri Jul 22, 2005 8:35 pm
they were run with stock springs before so i dont see why it would be a issue now
v
vvega
Postby RedMist » Fri Jul 22, 2005 11:01 pm
10k20v ran them with stock springs. However thought that with high RPM he should have shifted to an aftermarket spring.
I do know that they were rev'ed quite hard and appeared to have no gauling of the lobes so I'd say they should be fine.
Did you get the valves to use as templates? (although you shouldn't need them)
RedMist
Postby AceSniper » Sat Jul 23, 2005 2:51 am
thanks :) umm think they work out 274 9mm in and 290 8.9mm ex, while kelford thought they should have new springs, I didnt get much of an answer from franklin (from memory will have to look at emails)
AceSniper
black top 20 v
Postby Celica RA45 » Sat Jul 23, 2005 12:21 pm
have a mate that is running a std ecu and motor with 10.8 mm cam and 30degrees more at 50 thou and seems to be fine this is off a billet thou and is a waggott cam grind profile
Celica RA45
Postby 10k 20v » Sat Jul 23, 2005 4:30 pm
hmmm, i could possibly be persauded to part with my TODA Racing valve springs.
Unused and still in the box :wink:
The specs for those cams is 284 in (230 @ 50 thou) and 9.1mm lift
304 ex (240 @ 50 thou) and 8.9mm lift
10k 20v
Users browsing this forum: Google [Bot] and 30 guests
