GT-T I/C
GT-T I/C
Postby Santa'sBoostinSleigh » Thu Jul 28, 2005 10:26 am
OK, im starting to look at going the front mount route -
what i would like is some recommendations on a few things, im no super expert and i value everyones opinions :)
what size core would suit my GT-T?
any specific brands that are better/ones to stay away from?
what size piping to use? i was thinking maybe 2.5" stainless?
how hard is it to turn the turbo round - point it down? - to reduce bends etc
problems/hic-ups that may come along?
rough costs? for each bit etc
and any other info that anyone wants to share :)
ta
Andrew
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Rollux » Thu Jul 28, 2005 11:30 am
I've had good results from my Hybrid I/C GT Spec I got from Oz, 450x300x80, on my SR20DET Avenir. Replaced my factory front mount with it. It is a Bar and fin, a kinda cross between bar and plate and tube and fin, to try to get better cooling without impairing the flow. (I actually got a 3psi boost increase at the manifold just by replacing the IC!!) I'm only looking for about 280-300hp total(220hp stock), so it's not going to be overkill.
Oh, it cost me $565 shipped. Not sure if anyone here in NZ does them.
As for turning the turbo round, generally can be done (not too sure on a GTT tho), but you need to modify your wastegate actuator mounting bracket.
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Postby blitza » Thu Jul 28, 2005 11:42 am
good thought on clocking the compressor housing, sometimes there is a roll pin in the centre section for indexing that will have to come out.
good thought on the stainless too, everyone will be doing this soon.
MAD Industries Limited
blitza
Postby Santa'sBoostinSleigh » Thu Jul 28, 2005 1:47 pm
blitza wrote:good thought on clocking the compressor housing, sometimes there is a roll pin in the centre section for indexing that will have to come out.
have you done yours Blitza or are you still running top mount?
would the stainless be a benefit over ali or mild steel?
i can get dairy tube fairly easily, but this is quite thick walled hence heavier.. dunno if that really makes a difference or not, but its just one more thing to take into consideration i guess
Santa's Mega Sale
Postby Malcolm » Thu Jul 28, 2005 3:36 pm
I had the compressor housing rotated on my ct26 in my gt4. It's fairly easy to do, you just either remove the locating pin in the compressor housing, or you file a new keyway for it on the edge of the compressor backing plate on the center section (this is what I did).
Making the new bracket for the actuator is a tiny bit tricky as you have to make sure it doesn't interfere with the coolant lines, and that it puts enough tension on the wastegate that it doesn't leak!
On the gt4 there was only a small spot for the compressor outlet to point to, between the fan and the engine mount, so it would definitely be wise to decide on the position with the turbo still on the car, rather than just approximating.
2.5" might be a bit laggy, I don't really want to get into the argument of how much difference the volume of the piping makes, but I know that on a gt4 with a massive front mount (600x300x75) and 2.5" piping that I had a ride in, the guy reckoned there was hardly any lag but to me it felt like boost built very slowly, with no real kick as it came in, and probably didn't seem to reach full boost until well over 4K (on stock turbo). In comparision mine, with 2" piping and a much smaller vr4 intercooler hit full boost around 3,500 with a big kick, and that was on an upgraded ct26.
As far as material goes, stainless would be the best, as it wont rust, provided you use a low carbon content steel (ie 304L), as normal austenitic stainless steel will suffer from "weld decay" around welded joints and rust. Mild steel is the cheapest but you'd probably want to get it ceramic coated or similar to prevent rust (all mine + intake piping cost $130 to be ceramic + powder coated). Aluminium will never rust but it will more readily conduct hot air from the engine bay into the intake air and could fail due to fatigue if it is loaded frequently due to lack of joiners, hitting chassis etc under engine movement etc, will also probably cost the most to make
Postby Santa'sBoostinSleigh » Thu Jul 28, 2005 5:40 pm
cheers All_Fours,
what size core is yours?
another thing i just thought of is where would be the optimal places to use flexi joiner type things or is welding the whole lot solid ok?
Santa's Mega Sale
Postby Malcolm » Thu Jul 28, 2005 5:58 pm
don't quite remember the size of the vr4 ic, think it was around 400x270x60
you definitely want a couple of flexible hoses otherwise you'll get lots of banging and or breaking of pipes. Not sure on optimal positioning though
Postby Mr Revhead » Thu Jul 28, 2005 7:55 pm
just dont buy one of those repco ones, "racepro" i think they are. they are HORRIBLE 8O have a close look at one
Postby Malcolm » Thu Jul 28, 2005 8:00 pm
what's horrible about them? I had a close look and my main concern was the fact that when I looked through one of the inlets I could see a small bit of welding on one of the tubes (presumably to fix a leak?).
Postby Mr Revhead » Thu Jul 28, 2005 8:06 pm
the one on display here looks ok on the outside, but look into a pipe, and its disgusting, so so restrictive, bad welding, and just a poor design.
its worse than any stock one iv seen
Postby Rollux » Thu Jul 28, 2005 10:47 pm
Mr Revhead wrote: "racepro" i think they are.
Close, I beleive they are called "Ricepro" :lol: (or Gaypro, depending on where you're from)
Rollux
Postby blitza » Thu Jul 28, 2005 11:19 pm
haven't done mine yet, ss has better heat properties than ali, plus if you use polished pipes, they will be shinier and more resilient to scratching.
blitza
Postby Santa'sBoostinSleigh » Fri Jul 29, 2005 1:20 pm
what about you other GT-T boys, what have you done/recommend?
Santa's Mega Sale
Postby Dell'Orto » Fri Jul 29, 2005 3:43 pm
Mr Revhead wrote:the one on display here looks ok on the outside, but look into a pipe, and its disgusting, so so restrictive, bad welding, and just a poor design.
Says the man who sells dodgy thai knock off parts :lol:
Nah, the first generation of those Racepro coolers looked crap, but the 2nd lot we've had look identical to the Hybrid coolers you see around.
If you knew who made them, you wouldnt be so quick to say they're shit.
Postby Santa'sBoostinSleigh » Fri Jul 29, 2005 4:44 pm
so are the hybrid ones good then??
what would the price diff be between hybrid and racepro?
who makes them then Mmm, Boost? :D
still looking for info on the size of the core and piping i should go for!
Santa's Mega Sale
Postby Santa'sBoostinSleigh » Fri Jul 29, 2005 6:09 pm
would it be worth just front mounting the standard I/C?
Santa's Mega Sale
Postby Santa'sBoostinSleigh » Fri Jul 29, 2005 6:10 pm
Also i have an oil cooler with a fan off a 2.5L V6 TT VR4 Legnum motor, do ya rekon this might be worth installing in place of the standard caldina one?
Santa's Mega Sale
Postby Rollux » Fri Jul 29, 2005 8:52 pm
If you knew who made them, you wouldnt be so quick to say they're sh*t.
The racepro ones i saw looked crap, my Hybrid one looks 2000% better, and the welding and tanks are far better. Who does make the Ricepro ones? I can't say I've seen any Ricepro ones recently, but a 5 sec look was enough to turn me off them.
Rollux
Postby blitza » Fri Jul 29, 2005 11:12 pm
as far as mounting the oil cooler on top, not a bad idea. I am looking at making a part to go in the bonnet scoop hole to vent air out, will post when complete.
blitza
Postby Mr Revhead » Sun Jul 31, 2005 1:02 pm
well the ones they have here must be the old lot then, cause they are total rubbish! 8O
