apply the throttle, engine stalls.... :-S
Postby skoty » Thu Jul 28, 2005 10:47 pm
Basically the motors another bluetop 4age. Was running perfectly until a few days ago. Initally engine was hesitant to accelerate, then it would splutter and sound as if the engine was firing on the exhaust stroke and doing this random sh#t (take not engine timing has NOT been adjusted) Now the engine will barely idle and thats the only thing it can do, as soon as the throttle is applied, engine stalls, the only way to rev the engine is to continuosly tap the throttle a million times. Basically the car is undriveable, very inconvinient. Any ideas?
Profile - Cars Owned - AE82 Corolla GT / Corolla Dirt Track Car / N14 Pulsar GTI / S14 Silvia Qs / Nissan Van / Nissan Avenir GT
Current cars - Altezza RS200 and Mitsi Lancer GSR
skoty
Postby skoty » Thu Jul 28, 2005 10:49 pm
It almost sounds like the throttle position sensor (tps) but that hasnt been touched. My bet is on fuel but I need some ideas... :roll:
skoty
check timing belt
Postby andyztouring » Thu Jul 28, 2005 11:10 pm
check the timing marks on the cam cogs are OK and timing belt is tight,if the belt is loose,it can jump or slip a tooth and run poorly.
andyztouring
Postby Lanius » Fri Jul 29, 2005 10:09 am
vaccuum leak?
Lanius
Postby RedMist » Fri Jul 29, 2005 11:15 am
My money is also on fuel. Either filter or pump. Why dont you get a flow test? Have you tried running it on engine start? Not safe, but should tell you if its a fuel or a timing issue.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Kender » Fri Jul 29, 2005 12:49 pm
We had this problem with a car at work. It turned out to be that someone had replaced the hollow bolt that goes into the fuel filter with a normal solid bolt. So not enough fuel. Did you do any work on the car recently?
Start the engine, and see if it will rev while you're spraying crc engine start into the intake manifold. If it does, then you car's not getting enough fuel.
'84 AW11 SC racecar "RDDWRF"
'92 SW20 GT-S
'91 GT Legacy wagon
Kender
Postby Leon » Fri Jul 29, 2005 1:16 pm
borrow an ignitor off somebody, swap them over and see if that cures it.
Postby 85AW20v » Fri Jul 29, 2005 1:50 pm
Replaced the fuel filter lately?
See ya
Simon
85 MR2 20v
85AW20v
Postby trd__levin » Fri Jul 29, 2005 2:21 pm
if it was afm i would say the pipeing between the afm and intake but yeah... maybe the same sorta thing like an airleak..
trd__levin
Postby skoty » Fri Jul 29, 2005 6:44 pm
Simon85MR220v wrote:Replaced the fuel filter lately?
ummm... :oops: , I had the same idea also, quite possible really in would explain a lot.
skoty
Postby Loudtoy » Fri Jul 29, 2005 8:08 pm
And if it doesn't make sure your afm is plugged in, i had a similar problem that turned out to be i'd forgotten to plug the afm back in after some intake mod's :oops:
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby KinLoud » Fri Jul 29, 2005 10:00 pm
My money is on your cambelt.
Sometime when they get worn they will slip a couple of teeth due to the teeth breaking off the belt.
This affects your cam timing which can gives similar symptoms.
Ken
Ham
021 408 863
Postby BIG-AL » Fri Jul 29, 2005 11:04 pm
Check the hose from the throttle body to the air filter it may have a hole in it.
Alan.
BIG-AL
Postby skoty » Sat Jul 30, 2005 10:38 am
The car is MAP sensored, not AFM. So basically first two possible causes will be either a fuel restriction (f/filter) or the cambelt skipping a tooth or two baring in mind im unaware of when either were changed. The "engine check" light does not stay on when the engine is running therefore its unlikely one of the engine sensors has fukt out.
skoty
Postby skoty » Sun Jul 31, 2005 9:10 pm
Replaced filter, no fix as yet however it is definatly fuel because when I sprayed fuel in the intake it ran perfectly. So I guess it comes down to either faulty/blocked injectors or...?
skoty
Postby sergei » Mon Aug 01, 2005 1:01 am
Fuel Pump?
Postby RedMist » Mon Aug 01, 2005 7:59 am
Jesus Scotty. Read the fourth post down.
RedMist
Postby MrOizo » Mon Aug 01, 2005 10:39 am
Would go with the Fuel Pump. Had this prob in my AW11 also.
idles ok but when there was load and required more fuel, it spitted and farted....
MrOizo
Toyspeed Legend
Postby skoty » Mon Aug 01, 2005 9:49 pm
RedMist wrote:Jesus Scotty. Read the fourth post down.
Sorry, I was tired when I wrote that :P shit replacing the pump will b a pain in the ass as its an intank job :(
skoty
Postby YeMs » Mon Aug 01, 2005 11:04 pm
how bout try the fuel pump relay first? its pretty straight forward. or you could check for fault codes? a simple search on google brang up this:
http://www.troublecodes.net/Toyota/ and it will pretty much tell you your troubles ;) also u can bridge 2 terminals on your diagnosis plug to by pass your fuel pump relay which, if the relay is f*cked will turn the pump on and the car will run (if it is infact the relay thats gone, which is possible just as likely, if not more likely than the fuel pump)
also theres probly more than 1 fuel filter, just after the tank so mite pay to change that 1 to.
the injector issue, a guy tried to tell me thats whats wrong with my cressida, but it seems unlikely that all the injectors would stop working at the same time, its more likely that just 1 will stop and u will only have 3 cylinders firing.
u could try putting on a pulse light to see if your injectors are firing when u are cranking, but as i said before bring up the ecu fault codes and it will tell u whats wrong, saves money replacing things untill u find the problem
Your local Hybrid Elite tech
YeMs
Users browsing this forum: No registered users and 22 guests
