HRT wrote:And if you do replace that line (or cut it and put a joiner in) then make sure you use EFI fuel hose rather than standard stuff. The standard stuff isn't rated to anywhere near what the EFI stuff is. In saying that the EFI stuff is about $40/m or something stupid like that so you probably dont want to replace much
Oh cheers for the replies guys.
Yep its $44 a meter
So just cutting a section out and clamping some EFI hose in is alright, no warrent issues?
I mesured the OD of the pipe to be 7.25mm, the efi hoses ID is 8mm. The next one down is 6.4mm or something. Id like to buy 1m so i can rerout it, its in a damn stupid place. But it is quite expensive :S
Any idea on the cost of replacing the whole metal pipe? I believe they are held in place by some sort of a snap lock mechanisim. Theres one before it goes up into the engine bay.
