What is this line for?
Postby method » Fri Jul 29, 2005 8:47 pm
I couldnt quite track it but its the fatter one of the lines comming from the back. Is it a fuel line or a hydrolic line? Or something else.
Its quite damaged but there are no leaks of any sort. I presume it has far less flow that it used to too.
Would this be a warrent issue?
This is the line thats dmaged. They run down the left hand side, the pic is near the passanger door. Its a ae82 corolla.
Pic of the damage
Cheers.
PICS UPDATED DAILY
method
Postby Rick » Fri Jul 29, 2005 8:53 pm
Hard to tell but it can only be one of the following: fuel supply/return/breather or rear brake line looking at the pic I would say its a fuel line (supply or return) being a bit bigger than the other ones
Postby Low_Aa63 » Fri Jul 29, 2005 8:56 pm
cut it and find out!! :P
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
Low_Aa63
Postby method » Fri Jul 29, 2005 9:12 pm
Yeah, thought it could be the fuel lines. I dont experience any spluttering under full throttle so its still getting fuel which is good i guess?
What harm would a block in the return line pose?
Could something burst and cause a fire? (thinking of pics from the 'why you should get a Rising rate FPR' thread)
PICS UPDATED DAILY
method
Postby B ROWDY » Fri Jul 29, 2005 9:35 pm
Low_Aa63 wrote:cut it and find out!! :P
I like it, you have my style! :twisted:
B~ROWDY The Thread Whore Formerly Known As SERABABY
B ROWDY
Postby wde_bdy » Fri Jul 29, 2005 9:45 pm
Trace the line to the front of the car, most likely a return line or tank breather. Definitely fix it quick, cut the line, clean the end and then join it with EFI hose and clamps. I would look at some kind of protective cover if possible too.
Callum
wde_bdy
Postby method » Sun Jul 31, 2005 10:03 pm
Ok this is where the line leads to. Cant quite tell what the thing does but im sure you guys would know.
Any idea on what its for? It runs back to the fuel tank. Are there any dangers in using the car? Like overstressing the fuel pump or worse too much pressure that could cause somethign to burst?
Image[/url]
PICS UPDATED DAILY
method
Postby wde_bdy » Sun Jul 31, 2005 10:12 pm
Thats your fuel filter, don't drive it until you fix it.
wde_bdy
Postby Lloyd » Sun Jul 31, 2005 10:14 pm
And if you do replace that line (or cut it and put a joiner in) then make sure you use EFI fuel hose rather than standard stuff. The standard stuff isn't rated to anywhere near what the EFI stuff is. In saying that the EFI stuff is about $40/m or something stupid like that so you probably dont want to replace much ;)
Postby method » Sun Jul 31, 2005 10:28 pm
HRT wrote:And if you do replace that line (or cut it and put a joiner in) then make sure you use EFI fuel hose rather than standard stuff. The standard stuff isn't rated to anywhere near what the EFI stuff is. In saying that the EFI stuff is about $40/m or something stupid like that so you probably dont want to replace much ;)
Oh cheers for the replies guys.
Yep its $44 a meter 8O.
So just cutting a section out and clamping some EFI hose in is alright, no warrent issues?
I mesured the OD of the pipe to be 7.25mm, the efi hoses ID is 8mm. The next one down is 6.4mm or something. Id like to buy 1m so i can rerout it, its in a damn stupid place. But it is quite expensive :S
Any idea on the cost of replacing the whole metal pipe? I believe they are held in place by some sort of a snap lock mechanisim. Theres one before it goes up into the engine bay.
PICS UPDATED DAILY
method
Postby Rick » Sun Jul 31, 2005 10:53 pm
just go to pickapart (avondale) was there friday they had a AE82 FXGT just grab the whole line.
Postby wde_bdy » Sun Jul 31, 2005 11:03 pm
Last time I bought EFI fuel line it was about $10 for 1/2m from Repco, seen the same stuff at Supercheap too.
Callum
wde_bdy
Postby method » Sun Jul 31, 2005 11:25 pm
Oh was it, ill try and get some tomorrow. If that fails ill go to my local pick a part (avondale :D)
Cheers for that, never even though of going to pick a part :oops:.
PICS UPDATED DAILY
method
Postby AceSniper » Mon Aug 01, 2005 12:57 am
or find a place that does high pressure fittings... about $5 theres brass fittings with a coller that clamps onto each side of the line as the end caps are done up... there pritty much made for this... and they contain no rubber or anything fuel or fire will damage
AceSniper
Users browsing this forum: No registered users and 35 guests
