how do u know when to change the coil lead?Mr Revhead wrote:iridiums are over kill, platinums are more than fine.
the gain over the stock coil was prob casue your old one was poked, they are knowen to fail. also the coil lead on 20vs are prone to wearing out rapidly. i replace mine every 6 months or so. so on a stock engine, you wont find any gains on a high performance coil
i do get slightly rougher idle when my engine is warm, and how can i test it??Mr Revhead wrote:you may notice a slightly rougher idle, or you can test it.
i replace it often cause it costs stuff all so id rather do it as part of my usual servicing
Mr Revhead wrote:with a multi meter
check the resistance, cant remember the exact figure but around 8ohms per foot is the highest you want.
im sure ill be corrected if wrong!
