CDI application for ae111 blacktop
Postby gt20v » Sat Jul 30, 2005 12:23 am
Ive been offered a CDI unit from Ultra.is there any benefit at all to fit this in?
any problem at all?
I know there a benefit but disadvantage??
thank you.
gt20v
Postby ROBODISCO_20v » Sat Jul 30, 2005 6:23 pm
What is it first ?
ROBODISCO_20v
Postby Rick » Sat Jul 30, 2005 7:48 pm
CDI "Capacitive Discharge Ignition" or "Capacitor discharge Ignition"
Basically a CDI ignition system greatly increases the voltage available to the spark plug allowing for a longer, more intense spark. I would say quite pointless on a stock engine.
Postby ROBODISCO_20v » Sun Jul 31, 2005 6:47 pm
This system you've been offered what does it consist of? Is it just a more powerful coil or is it a full dizzy set up?
I've put an MSD coil on my levin & it was a definit improvement over the stock one.
If you want to take even better advantage of a more powerful coil get some NGK Iridium spark plugs and 7mm leads. This is what i have on done on mine. The standard iridium plug part number for a 20v is BKR6EIX11. If you have a turboed one you could go a heat range colder, 7. but you'd probarbly also want to go for a smaller gap which i dont think they do in iridium, i know you can get them i platinum though.
ROBODISCO_20v
Postby Lloyd » Sun Jul 31, 2005 6:58 pm
Because obviously you cant close down the gap on a sparkplug....
Postby ROBODISCO_20v » Sun Jul 31, 2005 7:03 pm
Well you're not surposed to on platinum & iridium tip plugs.
It can damage them and shorten their life span
ROBODISCO_20v
Postby Mr Revhead » Mon Aug 01, 2005 1:42 am
iridiums are over kill, platinums are more than fine.
the gain over the stock coil was prob casue your old one was poked, they are knowen to fail. also the coil lead on 20vs are prone to wearing out rapidly. i replace mine every 6 months or so. so on a stock engine, you wont find any gains on a high performance coil
Postby Xavier » Mon Aug 01, 2005 1:56 am
Mr Revhead wrote:iridiums are over kill, platinums are more than fine.
how do u know when to change the coil lead? :D
Cheers...
My Profile
1999 Altezza AS200 Z
1995 Trueno BZG (Previous)
1992 MR2 GTS (Previous)
Xavier
Postby Mr Revhead » Mon Aug 01, 2005 2:01 am
you may notice a slightly rougher idle, or you can test it.
i replace it often cause it costs stuff all so id rather do it as part of my usual servicing
Postby Xavier » Mon Aug 01, 2005 4:34 pm
Mr Revhead wrote:you may notice a slightly rougher idle, or you can test it.
i do get slightly rougher idle when my engine is warm, and how can i test it?? :D
Cheers...
My Profile
Xavier
Postby Mr Revhead » Mon Aug 01, 2005 4:39 pm
with a multi meter
check the resistance, cant remember the exact figure but around 8ohms per foot is the highest you want.
im sure ill be corrected if wrong!
Postby JT » Mon Aug 01, 2005 5:43 pm
Mr Revhead wrote:with a multi meter
LOL, 8 ohms :lol:
4age manual recommends no greater than 25K ohms for a single lead
JT
Postby Xavier » Mon Aug 01, 2005 5:51 pm
so which is which? if i got a multimeter, i just poke the both end and check the resistants getting 8 ohm or 25k ohm???
Cheers...
My Profile
Xavier
Postby Mr Revhead » Mon Aug 01, 2005 7:04 pm
jt looked in a book, i did it from memory
u choose :wink:
Postby sergei » Mon Aug 01, 2005 11:02 pm
should be in kOhms , wires act as resistive loads, to remove RF noise, etc...
Postby Lloyd » Mon Aug 01, 2005 11:16 pm
Rule of thumb is 8k per foot roughy. Some sets read higher and some lower. As long as they are all relative to each other and not too far from 8k per foot then they should be fine.
Postby Xavier » Mon Aug 01, 2005 11:46 pm
ok, if the reading is more than 8k ohm and less than 25k ohm, that should be alright, right? cos most of the coil lead is just over 1 foot long rite... :D
Cheers...
My Profile
Xavier
Postby Xavier » Tue Aug 02, 2005 4:58 pm
i measure one of the coil lead from the distributor, not to the spark plugs but to another part... measuring at 6.9k ohm, is that alright as it is about 1 foot long... :)
Cheers...
My Profile
Xavier
Postby ROBODISCO_20v » Sun Aug 14, 2005 4:06 pm
They cost the same, in some cases iridiums are cheaper. From personal experence I can say 20v's suit iridiums plugs better than platinum, they just seem to make the engine rev better.
ROBODISCO_20v
Postby CEvans » Sun Aug 14, 2005 7:09 pm
are trd leads any better than stock onrs?
CEvans
