stalling..over fueling. gx71 crusader-1geu
Postby YeMs » Sun Jul 31, 2005 6:51 pm
hey iv got a gx71 cressida with a 1geu. i just put the motor in last weekend (due to the old motor being fried... blown headgasket, and they kept driving it, got so hot the ht leads melted to the plugs/block lol) any way went mint on monday and tuesday then started like stalling, dropping revs for no reason. now it wont start atallbut smokes (blue smoke, very very fuely smelling) . has good compression (150psi even on all 6 cylinders) i have replaced the intake manifold gasket to be sure its not leaking. it has good spark, and good fuel pressure. are all these symptoms pointing to a crook air flow metre? is definately seriously over fueling wen trying to start it, if i remove the efi relay it will actually start and run on the remaining fuel in the chamber for a couple of seconds. a work mate had a theory that the injectors mite b f*cked but it seems unlikely that they would be mint for 2 days then all of a sudden all 6 stop working and just blow fuel in.
i guess all im asking for is a few different opinions of the issue? what u think the problem may be.
oh also the problem first started with the car would idle fine, but the second u touched the throttle the engine would die.
Your local Hybrid Elite tech
YeMs
Postby Low_Aa63 » Mon Aug 01, 2005 5:45 pm
try checking the earth on the injectors perhaps? its a comon mistake but alot of people still manage to forget about it!
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
Low_Aa63
Postby YeMs » Mon Aug 01, 2005 7:22 pm
over fueling.. not under fueling. and yeh the injector earths are definately on.
YeMs
Postby pervert » Mon Aug 01, 2005 7:24 pm
That sounds really similar to what my MTEU in a Cressida does when you try and start it with the $&#$% AFM, if that is any help. 8)
pervert
Postby Boldy » Tue Aug 02, 2005 8:36 am
you should be able to start it with the AFM unplugged, the EFI computer won't actually use the AFM reading at idle. It should idle ok but you won't be able to go anyway, soon as there is load on the engine it will die.
Does the timing check out?
Boldy
Postby pervert » Tue Aug 02, 2005 9:06 am
Boldy wrote:you should be able to start it with the AFM unplugged, the EFI computer won't actually use the AFM reading at idle. It should idle ok but you won't be able to go anyway, soon as there is load on the engine it will die.
Nah, it won't idle either on mine...and it is 100% definately the AFM.
pervert
Postby spencer » Tue Aug 02, 2005 11:06 am
They do use the afm reading at idle
ms63 crown
spencer
Postby Toymad » Tue Aug 02, 2005 2:02 pm
A lot of the Mk III Supras suffer this problem when the temperature sensor fails. It sees the engine as cold so injects more fuel. Note that this is the temperature sensor for the ECU; they use another sensor for the temp gauge in the dash.
I had it happen to me; at anything off idle it would die. Replacing that sensor did fix it, immediately.
It may not be the fault but it is something else to consider.
Toymad
Postby Boldy » Tue Aug 02, 2005 3:05 pm
I didn't think the AFM was used when the TPS was in the idle position, there was a default map that the ecu looked at. Could be wrong tho, sold the workshop manual along with the car a few months so meh.
Mine used to idle without the afm plugged in I remember cause I had forgotten to plug it back in tinkering around one day. It took me 20 mins to try and figure out why the thing was cutting out whenever I put it in drive, but would start in P or N.
anywho doesn't matter none, ah fond memories of the cressida tho!!!
Boldy
Postby Jebus » Tue Aug 02, 2005 6:49 pm
Toymad wrote:A lot of the Mk III Supras suffer this problem when the temperature sensor fails. It sees the engine as cold so injects more fuel. Note that this is the temperature sensor for the ECU; they use another sensor for the temp gauge in the dash.
A $&#$% thermo sensor or broken wire to the switch will cause exactly the symptoms you described. On a 4AGE the plug is green and on the rear of the head. Not entirely sure about the cressidas however. Definately give that a go.
Jebus
Users browsing this forum: Bing [Bot] and 7 guests
