light bulbs gone bung...
Postby RBRCHKN » Mon Aug 01, 2005 7:56 pm
in my sw20 about a month ago, the drivers side headlamp bulb blew. so i replaced it with some narva +50's. now the drivers side has gone really dull... like its on park or sumthin, but the park lights arent in the headlamp... sw20 owners will know what i mean :P
any ideas?
Adamal wrote:Then her hands started going to my funny places........
RBRCHKN
Postby Alex B » Mon Aug 01, 2005 8:01 pm
What are the contacts like? Maybe your earth.
Postby aliluya » Tue Aug 02, 2005 1:17 am
Did you touch the bulb by anychance ...
Sounds like your bulb is slowly on it way out already .... Generally caused by accidentally touching the glass ..
2008 Toyota Highland 4WD LTD is awesome!!!
2001 E39 530i BMW
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1727
aliluya
Postby MrOizo » Tue Aug 02, 2005 8:08 am
check your fuses... chances are you blew that ;)
MrOizo
Toyspeed Legend
Postby aliluya » Tue Aug 02, 2005 12:18 pm
But if you blew the fuse then the light wouldn't go at all ...
2001 E39 530i BMW
aliluya
Postby Alex B » Tue Aug 02, 2005 12:23 pm
Yes it would, does the same thing in my car now i think of it. Check fuses first :)
Postby Adamal » Tue Aug 02, 2005 2:05 pm
The bulbs are sealed beams, so can't touch the bulbs. That rule doesn't apply to halogen lamps though.
Sounds as if the filament is partially burnt out. Means death is soon around the corner!
Postby Ae92typeX » Tue Aug 02, 2005 3:30 pm
pyro_sniper2002 wrote:What are the contacts like? Maybe your earth.
yea, I'd check all the earths and plugs are clean as. have had similar experiences on many cars with rusty/dirty contacts and earths.
Ae92typeX
Postby Loudtoy » Tue Aug 02, 2005 8:00 pm
Adamal wrote:The bulbs are sealed beams, so can't touch the bulbs. That rule doesn't apply to halogen lamps though.
Do you mean the rule of you can't touch the lamps doesn't apply to halogen lamps??
PS bulbs grow in the garden
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
