dx nutters out there!!
Postby illicit » Thu Aug 04, 2005 7:05 pm
Whats involved in putting a 3t-gte into a ke70 wagon?
I could do the 4age route but a 3t-gte sounds quite appealing?
Anything can be modified even ugly cars
0210622606 if you think I can help
illicit
Postby z|gen » Thu Aug 04, 2005 7:08 pm
i suggest you use the search button..
:roll:
change engine mounts, fuel lines, g/box, brakes, suspension..
and please..dont call it a 'dx' either
AE91 SUPERCHARGED COROLLA
z|gen
Postby pervert » Thu Aug 04, 2005 7:15 pm
z|gen wrote:and please..dont call it a 'dx' either
:lol: :lol: :lol: :lol: :lol:
Awww c'mon, not everyone understand's about chassis codes...
DOHC Turbs bro...
pervert
dx
Postby illicit » Thu Aug 04, 2005 7:24 pm
Why can't i call it a dx? more people know it by that name!
I know it's a ke70 and so do toyota people,but I still don't see a problem.
I tried the search function but was no use as i wasn't sitting and reading 38 pages that contained those terms.
Any way,back to topic.
illicit
Postby z|gen » Thu Aug 04, 2005 7:41 pm
i told you in brief how to do it.
z|gen
Postby z|gen » Thu Aug 04, 2005 7:47 pm
you may also need to change your steering from rack'n'pinion to recirculating ball depending how much clearence you get with the engine, you will also need to change your clutch setup to hydraulic
z|gen
dx
Postby illicit » Thu Aug 04, 2005 7:57 pm
Kool, I dont meen to get grumpy but it happens occasionally :oops:
I think it could be quite a good option depending on how hard the necessary parts are to get!
illicit
Postby z|gen » Thu Aug 04, 2005 8:00 pm
parts are easy enough..i know of at least 2 engines for sale, then just finding a g/box will be the hard part, and anything else you cant do.
z|gen
Postby AE85coupe » Thu Aug 04, 2005 11:29 pm
if its older and still has steering box steering just use a TE71 crossmember or else get some engine mounts made up to suit
grab some struts from a TA61/TA63 etc. use the wagon springs and top hat, with the TA61 steering arm and theres your front brakes sorted (10 inch vented)
get the 3tgte out of wreck so you get the gearbox with it
you will need to set up the hydraulic clutch as well
bigger fuel lines and a high pressure fuel pump (and a surge tank setup would be a good idea)
you'll need a custom driveshaft and gearbox crossmember
Diff wise you could go for AE86 or TE71 and get the mounts setup for leaf spring or if you don't have much cash use a 10 bolt corona diff as they are just as strong and alot easier to find (but not disc brake)
or go nuts and do a hilux diff
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby gepsk8 » Thu Aug 04, 2005 11:40 pm
bellhousing go cheap on trademe to bolt to t50. 2t, 3t have the same bellhousing
gepsk8
Postby YeMs » Thu Aug 04, 2005 11:55 pm
gepsk8 wrote:bellhousing go cheap on trademe to bolt to t50. 2t, 3t have the same bellhousing
a 3tgte will eat a t50 in not long. best option is to go with a w55 like my setup.
Your local Hybrid Elite tech
YeMs
Postby YeMs » Fri Aug 05, 2005 12:02 am
also if your genuinely interested the setup in my ke30 can b bought for the right price. basically it will bolt into a dx, plus its gotta big turbo custom manifold link ecu so u dont have to worry about fking around with the factory ecu. PM me if your interested, plus i can tell u pretty much every thing about the conversion if you want as iv done it myself.
YeMs
