clutch replacment
clutch replacment
Postby JASON_SHEMAN » Fri Aug 05, 2005 1:00 pm
much much do u guys pay for a clutch replacement for st182 celica? i got quoted $900, is it expensive?
JASON_SHEMAN
Postby Xavier » Fri Aug 05, 2005 1:16 pm
standard clutch? or heavy duty? wat brand? i got my old car (FTO) done with heavy duty clutch around $800ish with flywheel machine...
make sure they include machining the flywheel as it would be a pain to get the out to do it again... :D
Cheers...
My Profile
1999 Altezza AS200 Z
1995 Trueno BZG (Previous)
1992 MR2 GTS (Previous)
Xavier
Postby celica_tommo » Fri Aug 05, 2005 1:22 pm
Go to BNT... probably about $250 from memory for an Exedy one. But yeah the best way to find out how much one is is to ring a few places that sell them. Then you'll know fo sure
celica_tommo
Postby JASON_SHEMAN » Fri Aug 05, 2005 1:58 pm
standard one with machining flywheel+gear box oil
JASON_SHEMAN
Postby fangsport » Fri Aug 05, 2005 3:24 pm
JASON_SHEMAN wrote:standard one with machining flywheel+gear box oil
including fitting??
fangsport
Re: clutch replacment
Postby AJz » Fri Aug 05, 2005 3:45 pm
JASON_SHEMAN wrote:much much do u guys pay for a clutch replacement for st182 celica? i got quoted $900, is it expensive?
Fukin jesus, i recently got a replacement gearbox not long ago, and had the clutch and flywheel machined at same time.
minus the gearbox price, was about 400ish (clutch kit, oils, labour, machine flywheel)
Cooke Howlison toyota quoted me $375 i think
how in gods name did he get $900 :?
try askin around another couple of places, shouldnt be more than $450.
I had vtax :(
AJz
Postby RS13 » Fri Aug 05, 2005 8:15 pm
Geez! I've never paid more than $650 for a clutch job, and that was my 180sx, and that was with a $350 clutch kit, and machining, and oil change.
I wouldn't go with the $900, I mean, its' just a simple FWD, I'd say an average amount would be about $400-$600 tops.
RS13
Postby JASON_SHEMAN » Fri Aug 05, 2005 8:30 pm
thax........
JASON_SHEMAN
Postby Lloyd » Fri Aug 05, 2005 8:36 pm
RWD is a lot quicker to do than a FWD.
Allow say 4 hours for a FWD which if you work off $70/hour + GST is a bit over $300 for labour. Some clucthes are more than others so allow another $300-350 for that depending on what its worth. Add on a couple of litres of gearbox oil, possibly rear main seal, flywheel machining etc. There is say $650 for clucth and labour alone without adding the other bits and pieces on
Check what you're actually getting a quote for too as the expensive ones might include everything and cheaper quotes might just be for the clutch and labour
Postby JASON_SHEMAN » Fri Aug 05, 2005 9:23 pm
so, would u pls give me a list of job need to be done onit? thx very much
JASON_SHEMAN
Postby Lloyd » Fri Aug 05, 2005 9:28 pm
Well you cant really tell until you're in there. Whoever you decide on, get them to check things such as gearbox fluid (probably drain it when taking the gearbox out anyway), rear main seal (in behind flywheel, change if leaking or do it anyway if you want to pay for it. If it leaks you get oil on the clutch and would need a new one), flywheel machining (might as well do that too, better than having it slip). Thats about what I would get done, flywheel machine, gearbox fluid and rear main seal.
Postby sergei » Sat Aug 06, 2005 10:41 am
btw rear main seal is about $10-20 anyway
clutch
Postby JasonZE » Sat Aug 06, 2005 2:06 pm
As HRT said depends on what they quote for?
I would generally quote for worst case senario ie rear seal,oil, machining,labour,genuine and aftermarket clutch kits which do vary either way by alot often nowdays genuine cheaper yesterday i quoted for an 1800cc imprezza non turb repco $750 for kit genuine $350!!! so this shows how you can get a high quote like yours so you need it on paper and whet you are getting.Sometimes people include slave cylinder for piece of mind so you need to check.
Most i do come in about $650-$700 all up. @ lab rate $70 inc gst.
I also advise a wheel alignment as when taking crossmembers and axles etc out it does effect alignment and we dont want worn tyres after a few hundred k's following clutch job
JasonZE
Real Life Mechanic
Postby thaphatty » Sat Aug 06, 2005 5:58 pm
including fitting??
for that price i should f**king hope so 8O
thaphatty
