lsd for corollas
lsd for corollas
Postby trdfxgt » Sun Aug 07, 2005 5:50 pm
hi i have been told that a gt starlet v has an lsd in its gear box which will fit in my ae 82 ???. axle size an things should be the same or so i have been told now this being said are there many of these about ? and is there any other gear boxes which have them ? or does a 6 speed out of a bz r have one ? and will any of these boxes fit in my car ? thanks heaps for any help
trdfxgt
Postby Ae92typeX » Sun Aug 07, 2005 7:35 pm
lots of 4agze's had lst boxes
try a search, heaps and heaps of posts
viewtopic.php?t=9716&highlight=4age+lsd
viewtopic.php?t=32117&highlight=lsd
Ae92typeX
Postby trdfxgt » Sun Aug 07, 2005 7:52 pm
i know ze s did but dont i have to change axles hubs and other things ??
trdfxgt
Postby ChaosAD » Mon Aug 08, 2005 1:50 pm
Some of the gze boxes have lsd's. But the added weight makes the benefits of fitting one debatable.
Some of the glanza boxes had them but they are viscous lsd's
Ive heard the celica boxes fit so maybe look into that.
ChaosAD
Postby Mr Revhead » Mon Aug 08, 2005 2:17 pm
celica and gtz boxes are "e" series, the starship has a "c" series like the ae82-ae101 non s/c corolla/levins etc. "e" lsd will not fit a "c"
i beleive the stock ones are viscous though, which maynot fit the stock casings. however with some mixing and matching i think it can be done.
youll need to budget for a gearbox rebuild as there no point having it all apart and not rebuilding it!
the simplest option is to try and get a c56 box from a bz-v levin as these has lsd stock. again viscous type
Postby trdfxgt » Sat Aug 13, 2005 9:41 am
sorry i have been aeay for a few days.. mr revhead what cars do the bz v boxes come in or is that a levin like bz g and bz r ?
trdfxgt
Postby Mr Revhead » Sat Aug 13, 2005 12:47 pm
thats the levin bz-v, trans code c-56 with a coupla other digits after that, your looking for one that ends in a "C" as oppoesd to an "A"
Postby ChaosAD » Sat Aug 13, 2005 4:23 pm
ChaosAD
Postby trdfxgt » Mon Aug 15, 2005 8:17 am
im just looking at a starlet gt box its out of a car how do i tell lsd or not cheers for that thread chaosAD but it only has tranz axle codes from the body they say its had once the box is out but if anyone can help thanks
trdfxgt
Postby ChaosAD » Mon Aug 15, 2005 6:54 pm
By turning the driveshafts as described above. If the other driveshaft turns the same way or not at all then its lsd. I think the glanza lsd boxes have an external fluid resivour or something.
Should be a bit of info in some of the old posts if you do a search
ChaosAD
Postby QikStarlie » Mon Aug 15, 2005 11:34 pm
factory starlet lsd box wont work. case is diffrent for the lsd and pretty sure they run diffrent axles.. shorter than non lsd box. along with diffrent mounting points on the box and e series bell housing, its not gonna happen on your ae82.
buy a trd lsd :D
QikStarlie
Postby trdfxgt » Tue Aug 16, 2005 4:04 pm
i was told by toyota that the lsd its self in the starlet is the identical part to the trd lsd for a ae82 box is this not the case ???
trdfxgt
Postby Mr Revhead » Tue Aug 16, 2005 4:05 pm
um, wot? :?
Postby trdfxgt » Wed Aug 17, 2005 11:41 am
edited read again sorry
trdfxgt
Postby Mr Revhead » Wed Aug 17, 2005 11:46 am
sweet.
ahh who told you that?? the stock starlet one is viscous, the TRD one is either helical or clutch pack type.
Postby ChaosAD » Wed Aug 17, 2005 5:14 pm
How much can you get those trd LSD's for?
ChaosAD
Postby trdfxgt » Wed Aug 17, 2005 8:39 pm
i got told that by my local toyota parts place
trdfxgt
Postby Mr Revhead » Wed Aug 17, 2005 10:52 pm
ah well either there was a misunderstanding.
or you were talking to a muppet
maybe they thought you meant the TRD ones cause some of them fit both
Postby trdfxgt » Thu Aug 18, 2005 8:34 am
ok cheers for that ill stick with the muppet theory what can you suply as far as an lsd for my car or are they available 2nd hand ? also what sort of money and if you dont mind a price on valve springs cheers..... if you want me to email just say cheers
trdfxgt
Postby Mr Revhead » Thu Aug 18, 2005 9:12 am
if you could itd be easier :wink:
